Home » Eclipse Projects » GEF » PropertyDescriptors in Shapes Example
PropertyDescriptors in Shapes Example [message #190738] Fri, 05 August 2005 13:48 Go to next message
Originally posted by: aroberts.optimistictech.com
I'm working my way through the Shapes example right now, and I can't
figure out why the models implement IPropertySource. I've never worked
with properties in Eclipse before, but it seems like Shapes sets up
Property descriptors for use in a property sheet, but I can't find
anywhere to actually view the property sheet.
Are these property descriptors used for some other purpose, or is the
Property Sheet just buried somewhere? If anyone could help me make
sense of this, I'd appreciate it.
Andrew
Re: PropertyDescriptors in Shapes Example [message #190770 is a reply to message #190738] Fri, 05 August 2005 15:03 Go to previous messageGo to next message
> Andrew
It's used by the Eclipse properties view, EditPart checks your model to
see if it implements IPropertySource and if it does it adapts properly
to IPropertySource.class
~ Chris
Re: PropertyDescriptors in Shapes Example [message #191049 is a reply to message #190738] Mon, 08 August 2005 12:47 Go to previous message
Originally posted by: pbeagan.yahoo_nospam_.com
Yes, it's for the property sheet. It does not come up by default when
running the example. Window > Show View > Properties
> Andrew
Previous Topic:SnaptoGeometry!!!
Next Topic:TextFlow and Text Alignment
Current Time: Sat Jul 26 05:18:43 EDT 2025
Powered by FUDForum. Page generated in 1.08214 seconds
