Home » Eclipse Projects » Eclipse Platform » strange behaviour of SearchUI ( search result view)
| strange behaviour of SearchUI ( search result view) [message #190467] |
Fri, 06 February 2004 05:03  |
Originally posted by: mirk.tonia.ch
I'm trying to integrate search support into my plugin.
i wrote a own search page and now i want to display the results in the search view.
i took a look at the help search page implementation to find out how this is done.
the search operation runs without an exception but the search result is not
displayed. only after i run a second search i can display the first search by
using the "previous search result" button in the search result view's toolbar.
after that the search result is diplayed corectly. but when i try to remove a search
result with the the "remove selected match" or "remove all matches" action of the search
result view, the match won't go away ( it is still displayed but trying to run the gotoaction
results in in a org.eclipse.core.internal.resources.ResourceException: Marker id: 1824 not found.)
below i posted my performAction method ( SearchPage implementation ) and
my implementation of the searchoperation ( BSPSearchOperation )
thanks for your help
ps im using
Version: 2.1.1
Build id: 200306271545
on linux ( gtk version )
i have not tryed on other platforms so far
my perform action looks like this
public boolean performAction() {
SearchUI.activateSearchResultView();
// get the runnableContext
IRunnableContext context= null;
context= getContainer().getRunnableContext();
if (context == null)
context= new ProgressMonitorDialog(getControl().getShell());
BSPSearchOperation op = new BSPSearchOperation(
new EOFetchSpecification( AntragSteller.ENTITY_NAME(), qualifierPart.getQualifier(), null),
PAGE_ID
try {
context.run(true, true, op);
} catch (InvocationTargetException ex) {
ExceptionHandler.handle(ex, SearchMessages.getString("Search.Error.search.title"),SearchMessages.getString( "Search.Error.search.message")); //$NON-NLS-2$ //$NON-NLS-1$
return false;
} catch (InterruptedException e) {
return false;
IStatus status= op.getStatus();
if (status != null && !status.isOK()) {
String title= SearchMessages.getString("Search.Problems.title"); //$NON-NLS-1$
ErrorDialog.openError(getShell(), title, null, status); //$NON-NLS-1$
return true;
// the search operation implementation class
package ch.oekoso.bsp;
import java.lang.reflect.InvocationTargetException;
import org.eclipse.core.internal.resources.MarkerInfo;
import org.eclipse.core.resources.IMarker;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.OperationCanceledException;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.operation.IRunnableWithProgress;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.jface.viewers.IBaseLabelProvider;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.search.ui.IActionGroupFactory;
import org.eclipse.search.ui.IGroupByKeyComputer;
import org.eclipse.search.ui.ISearchResultView;
import org.eclipse.search.ui.ISearchResultViewEntry;
import org.eclipse.search.ui.SearchUI;
import org.eclipse.swt.graphics.Image;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.actions.WorkspaceModifyOperation;
import stuff.GlobalUtils;
import com.sun.corba.se.internal.CosNaming.NSORB;
import com.webobjects.eocontrol.EOEditingContext;
import com.webobjects.eocontrol.EOEnterpriseObject;
import com.webobjects.eocontrol.EOFetchSpecification;
import com.webobjects.eocontrol.EOGlobalID;
import com.webobjects.eocontrol.EOQualifier;
import com.webobjects.foundation.NSArray;
import com.webobjects.foundation.NSDictionary;
* @author mirko
* To change the template for this generated type comment go to
* Window>Preferences>Java>Code Generation>Code and Comments
public class BSPSearchOperation extends WorkspaceModifyOperation {
private EOFetchSpecification spec;
private String page_id;
private IAction goToAction;
private ILabelProvider labelProvider;
private IGroupByKeyComputer groupByKeyComputer;
private IActionGroupFactory actionGroupFactory;
// main constructor
public BSPSearchOperation( EOFetchSpecification spec, String page_id, ILabelProvider labelProvider, IAction goToAction, IGroupByKeyComputer computer, IActionGroupFactory factory ) {
this.spec = spec;
this.page_id = page_id;
createLabelProvider(labelProvider);
createGoToAction(goToAction);
createGroupByKeyComputer(computer);
createActionGroupFactory(factory);
// simple constructor
public BSPSearchOperation ( EOFetchSpecification spec, String page_id ) {
this(spec, page_id, null, null, null, null);
private void createLabelProvider (ILabelProvider provider) {
if ( provider != null ) {
labelProvider = provider;
return;
this.labelProvider = new LabelProvider() {
public String getText(Object element) {
try {
ISearchResultViewEntry entry =
(ISearchResultViewEntry) element;
return (String) entry.getSelectedMarker().getAttribute(
BSPSearchSupport.MARKER_KEY_LABEL);
} catch (CoreException ce) {
return "";
public Image getImage(Object element) {
return Bespielungsplan.getImages().getImage(BSPImages.ICON_ENTITY_P ERSON);
private void createGoToAction (IAction action) {
if ( action != null ) {
this.goToAction = action;
return;
goToAction = new org.eclipse.jface.action.Action() {
public void run() {
ISearchResultView view = SearchUI.getSearchResultView();
view.getSelection();
ISelection selection = view.getSelection();
Object element = null;
if (selection instanceof IStructuredSelection)
element =
((IStructuredSelection) selection).getFirstElement();
if (element instanceof ISearchResultViewEntry) {
try {
EOEnterpriseObject eo = BSPSearchSupport.eoFromMarker(
new EOEditingContext(),
Bespielungsplan.getDefault().getEditorRegistry().openEditor( eo);
} catch (Exception e) {
System.out.println(e);
private void createGroupByKeyComputer ( IGroupByKeyComputer computer ) {
if ( computer != null ) {
this.groupByKeyComputer = computer;
return;
this.groupByKeyComputer =new IGroupByKeyComputer() {
public Object computeGroupByKey(IMarker marker) {
try {
if (marker
.getAttribute(BSPSearchSupport.MARKER_KEY_GID)
!= null)
return marker.getAttribute(
BSPSearchSupport.MARKER_KEY_GID);
ce.printStackTrace();
return "UNKNOWN" + System.currentTimeMillis();
private void createActionGroupFactory ( IActionGroupFactory factory ) {
this.actionGroupFactory = factory;
protected void execute(IProgressMonitor monitor)
throws CoreException, InvocationTargetException, InterruptedException {
try {
ISearchResultView sView = SearchUI.getSearchResultView();
NSArray eos = Session.session().defaultEditingContext().objectsWithFetchSp ecification(spec);
displayResults(eos, sView);
} catch (InvocationTargetException iex ) {
monitor.done();
throw iex;
} catch (OperationCanceledException oce) {
monitor.done();
throw oce;
} catch (InterruptedException oce) {
monitor.done();
throw oce;
monitor.done();
private void displayResults(NSArray results, ISearchResultView sView) throws CoreException, InvocationTargetException, InterruptedException {
ImageDescriptor imgDesc = Bespielungsplan.getImages().getImageDescriptor(BSPImages.ICO N_ENTITY_PERSON);
String qualiString = spec.qualifier().toString();
qualiString = qualiString.substring(1);
String label = qualiString + " - " + results.count() + " " + spec.entityName();
if (sView != null) {
sView.searchStarted(
(IActionGroupFactory) actionGroupFactory,
label,
label,
imgDesc,
page_id,
labelProvider,
goToAction,
groupByKeyComputer,
this
// Delete all previous results
Bespielungsplan.getDefault().getResource().deleteMarkers(
BSPSearchSupport.MARKER_ID,
true,
IResource.DEPTH_INFINITE);
createResultsMarkers(results, sView);
sView.searchFinished();
private void createResultsMarkers(NSArray results, ISearchResultView sView) {
for (int i = 0; i < results.count(); i++) {
EOEnterpriseObject eo = (EOEnterpriseObject)results.objectAtIndex(i);
EOGlobalID gid = eo.editingContext().globalIDForObject(eo);
NSDictionary dict = GlobalUtils.eoutils().primaryKeyForObject(eo.editingContext( ), eo);
//System.out.println(gid);
try {
IMarker marker = null;
marker = BSPSearchSupport.createMarker(eo);
sView.addMatch(
eo.userPresentableDescription(),
marker.getAttribute(BSPSearchSupport.MARKER_KEY_GID),
marker.getResource(),
marker);
public IStatus getStatus() {
return null;
Current Time: Thu Nov 06 15:05:28 EST 2025
Powered by FUDForum. Page generated in 0.03798 seconds
