Poll: Articles to be written on using GEF [message #18062] |
Mon, 26 August 2002 20:04  |
Originally posted by: hudsonr.spam.com
I would like to take a poll to know which subjects should be covered first
in our reference section. Examples might include:
Creating connections in GEF
Using the Platform (SWT) Drag and Drop support w/GEF
How to extend keyboard support in GEF
Using "Direct Edit" in GEF
Creating complex figures in draw2d
Re: Poll: Articles to be written on using GEF [message #19188 is a reply to message #18062] |
Mon, 09 September 2002 17:07   |
Here are two suggestions:
1) How to properly subclass Figure.
2) Subclassing Figure for use in GEF diagrams.
But before you do that, completed Javadoc would also be greatly
appreciated. For example, from ImageCache:
checkout
public static Image checkout(Dimension d,
Object o)
Returns an image that is at least as big as the desired size. NOTE: (1)
The client should not dispose the image that is checked out (2) However,
the client should check the image back in when done (3) The given
dimension will not be modified by this method (4) The client should not
use the returned image's bounds for anything (since the returned image
could be bigger than requested) (5) If the size of the image is too big,
and the image cannot be created, this method will return null
Parameters:
d - The desired size of the image to be checked out
This is a pretty nice entry, however, what is the Object o parameter
used for? This Javadoc entry is frustrating for two reasons: (1) @param
o isn't documented at all (2) @param o's name is not meaningful.
Thanks in advance,
Dave
Dave Orme
Advanced Systems Concepts
http://www.asc-iseries.com
Re: Articles to be written on using GEF [message #19501 is a reply to message #18062] |
Wed, 11 September 2002 05:59  |
Originally posted by: amode.arrakis.es
That articles are OK ! But I think it would be interesting for the beginners
in GEF like me to write a small tutotial about building a graphical editor
with GEF step by step. It isn't necessary the example editor be complex. If
this tutorial exists now, please tell me where it is.
Thank you !
FUDForum. Page generated in 0.05321 seconds
