Home » Eclipse Projects » Eclipse Website » Better template.php ?
Better template.php ? [message #18057] Mon, 13 November 2006 22:52 Go to next message
So ... the basic template for generating pages in projects using this
php Phoenix magic looks like this:
--- snip -----
<?php ## The "require" magic is "off-screen"
# Begin: page-specific settings. Change these.
$pageTitle = "Sample Phoenix web page using the new templates";
$pageKeywords = "Type, page, keywords, here";
$pageAuthor = "Type your name here";
# Add page-specific Nav bars here
# $Nav->addCustomNav("My Link", "mypage.php", "_self", 3);
# $Nav->addCustomNav("Google", "http://www.google.com/", "_blank", 3);
# Paste your HTML content between the EOHTML markers!
$html = <<<EOHTML
html goes here.
EOHTML;
# Generate the web page
$App->generatePage($theme, $Menu, $Nav, $pageAuthor, $pageKeywords,
$pageTitle, $html);
--- snip -----
I am not very familiar with PHP but the $html = <<< EOHTML line is
really making the HTML content be buried in the PHP code. This is bad
for 2 reasons:
1) I can't use simple PHP include(file) directive to include content
that I may need in more then 1 place.
2) The PHPEclipse editor syntax highlighting is completely shot for the
HTML that is buried in the PHP code.
I read a little about output buffering in PHP and this template seems
more logical to me and fixes these 2 issues.
Changes have the <-- comment next to them
--- snip -----
<?php ## The require magic is "off-screen"
ob_start(); # <-- turns on buffering
# <-- now close the PHP code section
HTML goes here. PHPEclipse will nicely hilite the syntax because now it
knows that it is in the "html" area and give me HTML templates as I need
them via code assist.
You can do also things like <?= $pageAuthor ?> which are PHP escapes for
expressions.
You can also include pages such as ...
<?php include("some.page.html") ?>
<?php
# Generate the web page.
# <-- ob_get_clean() will get the currently produced output which
# <-- sits in the buffer and erase the buffer so that
# <-- App->generatePage() can do the chrome around the page content
$pageTitle, ob_get_clean() );
--- snip -----
This is working locally, on local.eclipe.org installation, and I presume
that it should work on Eclipse.org once checked in. However, there may
be some php configuration parameters that may not be set in the same way.
Anything that I am missing ?
-michal
Re: Better template.php ? [message #18069 is a reply to message #18057] Tue, 14 November 2006 10:56 Go to previous messageGo to next message
That is the way I write pages for the eclipse.org website. See for
example: /projects/europa.php
The only additional thing I use is:
$html = ob_get_contents();
ob_end_clean();
$App->generatePage( ..., $html, ... );
The ob_end_clean allows further code to write to the output stream
normally. See http://us3.php.net/ob_get_contents
Re: Better template.php ? [message #18081 is a reply to message #18069] Tue, 14 November 2006 12:19 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Indeed, Bjorn's use of the output buffer makes a much cleaner (and
better) implementation. Most of our pages use it, but I have yet to
update the templates.
D.
> ob_end_clean();
Re: Better template.php ? [message #18622 is a reply to message #18081] Tue, 14 November 2006 12:24 Go to previous messageGo to next message
Actually, most of the newer pages I create are set up for
multi-language/localized content:
template.php:
-- snip --
# Place your html content in a file called content/en_template.php
include($App->getLocalizedContentFilename());
$App->generatePage(...)
--snip--
Where all my HTML content lies in
content/[en|fr|de|etc...]_template.php, allowing for localized content.
D.
> D.
>> ob_end_clean();
Re: Better template.php ? [message #18644 is a reply to message #18069] Tue, 14 November 2006 13:29 Go to previous message
Sounds good.
-m
> ob_end_clean();
Re: Better template.php ? [message #570105 is a reply to message #18057] Tue, 14 November 2006 10:56 Go to previous message
ob_end_clean();
Re: Better template.php ? [message #570119 is a reply to message #18069] Tue, 14 November 2006 12:19 Go to previous message
D.
> ob_end_clean();
Re: Better template.php ? [message #581087 is a reply to message #18081] Tue, 14 November 2006 12:24 Go to previous message
template.php:
-- snip --
--snip--
D.
> D.
>> ob_end_clean();
Re: Better template.php ? [message #581101 is a reply to message #18069] Tue, 14 November 2006 13:29 Go to previous message
Sounds good.
-m
> ob_end_clean();
Previous Topic:How to get <ul> list elements with out dashed lines
Next Topic:HTTP Proxy and PHP ?
Current Time: Sat Aug 30 23:42:00 EDT 2025
Powered by FUDForum. Page generated in 0.04008 seconds
