Home » Language IDEs » C / C++ IDE (CDT) » Debug console not displaying program output
Debug console not displaying program output [message #190174] Thu, 26 April 2007 17:33 Go to next message
Originally posted by: exceed.nc.rr.com
Hi all,
When I'm trying to debug in CDT the console isn't displaying the output.
For example if I write a simple hello world program or something,
nothing will print to the console output in the debugger. I already have
all my paths set up and whatnot so I can step through code. But if I am
for example stepping through code that requires a keyboard input, the
prompt does not appear in the console and so therefore I can't go
anywhere from there :)
Any ideas on this? Thanks..
- Brandon
Re: Debug console not displaying program output [message #190181 is a reply to message #190174] Thu, 26 April 2007 17:37 Go to previous messageGo to next message
Brandon Squizzato wrote:
> Hi all,
> - Brandon
Sorry I forgot to give my version info. I'm running:
Eclipse 3.2.2
CDT 3.1.2
Cygwin gdb 6.5.50 and gcc 3.4.4
Re: Debug console not displaying program output [message #190189 is a reply to message #190181] Fri, 27 April 2007 02:06 Go to previous messageGo to next message
Do you watch the gdb output console or the output console of your app?
Axel
Re: Debug console not displaying program output [message #190197 is a reply to message #190189] Fri, 27 April 2007 02:13 Go to previous messageGo to next message
I've tried looking at both. The if I use gdb in verbose mode it spits
out everything it should be when it runs, but no program output. And no
program output on the application console itself either.
>>> output. For example if I write a simple hello world program or
>>> something, nothing will print to the console output in the debugger.
> Axel
Re: Debug console not displaying program output [message #203028 is a reply to message #190181] Thu, 18 October 2007 02:56 Go to previous message
Originally posted by: Roland.Minde.ac-b.de
now I have suddenly exactly the same problem.
My workaround (which solves not the problem):
use Compiler Option -Wl,-subsystem,console
and the output goes to a popup window (not the console window in eclipse).
I am running:
Windows XP
Eclipse 3.3.0
CDT 4.0.0
MinGW 5 1.3 with gdb 6.6
Best Regards
Roland
"Brandon Squizzato" <exceed@nc.rr.com> schrieb im Newsbeitrag
news:f0r635$353$2@build.eclipse.org...
>> Hi all,
>> For example if I write a simple hello world program or something, nothing
>> will print to the console output in the debugger. I already have all my
>> paths set up and whatnot so I can step through code. But if I am for
>> example stepping through code that requires a keyboard input, the prompt
>> does not appear in the console and so therefore I can't go anywhere from
>> there :)
>> - Brandon
> Eclipse 3.2.2
> CDT 3.1.2
Previous Topic:How to configure Run dialog if my application need root account?
Next Topic:Viewing the return value
Current Time: Sat Jul 19 23:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.04250 seconds
