getOrigin()/setOrigin() in ScrolledComposite [message #18052] |
Thu, 19 April 2007 04:13  |
Originally posted by: roberto.sanchez.autonomind.com
Hi, I'm having problems with ScrolledComposite.
Method getOrigin() in org.eclipse.rap.rwt.custom.ScrolledComposite.java
always return (0, 0), because content.getLocation() returns Point(0,0)
although the scroll origin isn't at the beginnig of the content
public Point getOrigin() {
checkWidget();
Point result;
if( content == null ) {
result = new Point( 0, 0 );
} else {
Point location = content.getLocation();
result = new Point( -location.x, -location.y );
return result;
And when I call setOrigin the ScrolledComposite behaviour isn't fine, I
lose scrollbars or I'm not be able to reach the top of my content any more.
Any help ?
Regards.
Roberto.
Re: getOrigin()/setOrigin() in ScrolledComposite [message #18078 is a reply to message #18052] |
Thu, 19 April 2007 05:23   |
Hi again, I think that the problem is a Javascript problem, the
ScrolledComposite.java seems to be well implemented but when content has
a negative location (setted manually with setOrigin()) the browser
doesn't know how to paint it and when the scrollbars are moved by the
user the content location in ScrolledComposite.java isn't modified, so
if you call getOrigin() the value returned is obsolete.
I hope that can help you to solve it.
Bye.
> checkWidget();
> Point result;
> } else {
> return result;
> Any help ?
> Regards.
> Roberto.
Re: getOrigin()/setOrigin() in ScrolledComposite [message #18843 is a reply to message #18708] |
Thu, 19 April 2007 11:18  |
OK, I will use bugzilla next time :-)
This was faster for me and I'm a bit impatient ;-)
Regards.
Frank Appel wrote:
> thank you very much for posting this problem. We will check how to solve it.
> One note beside: It is easier for us to handle Bugs if they are posted in
> the eclipse bugzilla database. It ensures that bugs don't get 'lost' or
> forgotten. It is also easier for you to trace the progress and status of the
> bug. You can easily create a new bugzilla account at:
> https://bugs.eclipse.org/bugs/createaccount.cgi
> After that you can enter new entries at:
> https://bugs.eclipse.org/bugs/enter_bug.cgi
> select technology -> RAP. After that you are on the 'Enter Bug' form. For
> feature requests select 'Enhancement' from the severity dropdown.
> Ciao
> Frank
> "Roberto Sánchez" <roberto.sanchez@autonomind.com> schrieb im Newsbeitrag
> news:f07cf8$gdq$1@build.eclipse.org...
>> ScrolledComposite.java seems to be well implemented but when content has a
>> negative location (setted manually with setOrigin()) the browser doesn't
>> know how to paint it and when the scrollbars are moved by the user the
>> content location in ScrolledComposite.java isn't modified, so if you call
>> Bye.
>>> checkWidget();
>>> Point result;
>>> } else {
>>> return result;
>>> more.
>>> Any help ?
>>> Regards.
>>> Roberto.
FUDForum. Page generated in 0.02980 seconds
