Home » Eclipse Projects » Remote Application Platform (RAP) » getOrigin()/setOrigin() in ScrolledComposite
getOrigin()/setOrigin() in ScrolledComposite [message #18052] Thu, 19 April 2007 04:13 Go to next message
Originally posted by: roberto.sanchez.autonomind.com
Hi, I'm having problems with ScrolledComposite.
Method getOrigin() in org.eclipse.rap.rwt.custom.ScrolledComposite.java
always return (0, 0), because content.getLocation() returns Point(0,0)
although the scroll origin isn't at the beginnig of the content
public Point getOrigin() {
checkWidget();
Point result;
if( content == null ) {
result = new Point( 0, 0 );
} else {
Point location = content.getLocation();
result = new Point( -location.x, -location.y );
return result;
And when I call setOrigin the ScrolledComposite behaviour isn't fine, I
lose scrollbars or I'm not be able to reach the top of my content any more.
Any help ?
Regards.
Roberto.
Re: getOrigin()/setOrigin() in ScrolledComposite [message #18078 is a reply to message #18052] Thu, 19 April 2007 05:23 Go to previous messageGo to next message
Hi again, I think that the problem is a Javascript problem, the
ScrolledComposite.java seems to be well implemented but when content has
a negative location (setted manually with setOrigin()) the browser
doesn't know how to paint it and when the scrollbars are moved by the
user the content location in ScrolledComposite.java isn't modified, so
if you call getOrigin() the value returned is obsolete.
I hope that can help you to solve it.
Bye.
> checkWidget();
> Point result;
> } else {
> return result;
> Any help ?
> Regards.
> Roberto.
Re: getOrigin()/setOrigin() in ScrolledComposite [message #18708 is a reply to message #18078] Thu, 19 April 2007 07:10 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
thank you very much for posting this problem. We will check how to solve it.
One note beside: It is easier for us to handle Bugs if they are posted in
the eclipse bugzilla database. It ensures that bugs don't get 'lost' or
forgotten. It is also easier for you to trace the progress and status of the
bug. You can easily create a new bugzilla account at:
https://bugs.eclipse.org/bugs/createaccount.cgi
After that you can enter new entries at:
https://bugs.eclipse.org/bugs/enter_bug.cgi
select technology -> RAP. After that you are on the 'Enter Bug' form. For
feature requests select 'Enhancement' from the severity dropdown.
Ciao
Frank
"Roberto S
Re: getOrigin()/setOrigin() in ScrolledComposite [message #18843 is a reply to message #18708] Thu, 19 April 2007 11:18 Go to previous message
OK, I will use bugzilla next time :-)
This was faster for me and I'm a bit impatient ;-)
Regards.
Frank Appel wrote:
> Ciao
> Frank
> "Roberto Sánchez" <roberto.sanchez@autonomind.com> schrieb im Newsbeitrag
> news:f07cf8$gdq$1@build.eclipse.org...
>> ScrolledComposite.java seems to be well implemented but when content has a
>> negative location (setted manually with setOrigin()) the browser doesn't
>> know how to paint it and when the scrollbars are moved by the user the
>> content location in ScrolledComposite.java isn't modified, so if you call
>> Bye.
>>> checkWidget();
>>> Point result;
>>> } else {
>>> return result;
>>> more.
>>> Any help ?
>>> Regards.
>>> Roberto.
Previous Topic:JAX in Wiesbaden, Germany
Next Topic:Lost connection with server
Current Time: Tue May 06 01:46:21 EDT 2025
Powered by FUDForum. Page generated in 0.04990 seconds
