Home » Modeling » GMF (Graphical Modeling Framework) » Showing progress monitor
Showing progress monitor [message #190065] Thu, 29 May 2008 08:19 Go to next message
Originally posted by: novak.igor.gmail.com
Hi!
I define progress monitor as following:
AbstractTransactionalCommand command = new
AbstractTransactionalCommand(...){
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
monitor.beginTask("Updating model", 100);
doStuff(monitor);
monitor.done(); return CommandResult.newOKCommandResult();
Shell shell =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l();
ProgressMonitorPart progressMonitor = new ProgressMonitorPart(shell, null);
OperationHistoryFactory.getOperationHistory().execute(comman d,
progressMonitor, null);
but the progress monitor is not shown.
How to define a progress monitor to be shown in doExecuteWithResult or in
my doStuff method?
P.S. This is my third post of the same subject, I always get answer to my
questions, except this one ... should this question be in some other forum?
Thanks in advance, Igor Novak
Re: Showing progress monitor [message #190114 is a reply to message #190065] Thu, 29 May 2008 09:34 Go to previous messageGo to next message
Hello Igor,
Here you create ProgressMonitor directly inside the Shell. I think it's good
idea to put yout progress monitor into another Composite located inside your
dialog/view..
In addition you have to specify some layout constraints to make it correcltly
displayed.
Alex Shatalin
Re: Showing progress monitor [message #190276 is a reply to message #190065] Fri, 30 May 2008 07:55 Go to previous message
Originally posted by: jan.herriger.gmx.de
Hi Igor,
following opens a JFace dialog with progress bar:
ProgressMonitorDialog pmd = new ProgressMonitorDialog(myShell);
pmd.setCancelable(true);
pmd.create();
IProgressMonitor monitor = pmd.getProgressMonitor();
try {
pmd.run(true, true,
new IRunnableWithProgress() {
public void run(IProgressMonitor monitor)
throws InvocationTargetException, InterruptedException {
int steps = 100
monitor.beginTask("My Task", steps);
while (steps >0)
if (monitor.isCanceled()) {
//do something or just break loop...
monitor.subTask("My Subtask");
//do some work...
monitor.worked(1);
steps--;
catch (InvocationTargetException ex1) {...}
catch (InterruptedException ex2) {...}
if (monitor.isCanceled()) {...}
Jan
Previous Topic:How to detect a malformed SVG image
Next Topic:Bounds / figures / compartment / visible
Current Time: Fri Jul 18 17:14:55 EDT 2025
Powered by FUDForum. Page generated in 0.07550 seconds
