Home » Archived » Test and Performance Tools Platform (TPTP) » What Can Hyades Do?
What Can Hyades Do? [message #18037] Wed, 18 May 2005 11:36 Go to next message
Originally posted by: drewery.uk.ibm.com
We are looking into using Hyades in our test system for logging and Log
analysis.
But we need clarification on part of its function.
We need a logging tool that can take 'actual' and 'expected' results,
compare the two and then tell us whether the test has passed.
So if we have coded up a test we log what is actually happenning (using
Hyades) but also log what we expect to happen. We then need Hyades to
compare the two and tell us if the test passed or Failed.
Can Hyades do this currently? If not are any extensions being developed in
this functional area?
Can anyone help?
Sarah Drewery
Re: What Can Hyades Do? [message #18091 is a reply to message #18037] Thu, 19 May 2005 08:00 Go to previous message
Hi Sarah,
I believe you are looking for an arbiter implementation for your test
execution (e.g. 'actual' and 'expected' results). Unfortunately, TPTP does
not provide any such function. However, I would suggest to use the JSR-047
or Java Logging support in TPTP (see File >> New >> Example >> Hyades
Logging) to log your 'actual' and 'expected' results to two local files and
then run your arbitration code to resolve the verdict of the test case. A
good resource would be with the 2005 EclipseCon tutorials
(http://www.eclipse.org/tptp/ >> Documentation). For your specific
scenario, I would suggest the tutorial titled 'Using TPTP Logging and
Monitoring Tools' and its source code.
Paul
"Sarah Drewery" <drewery@uk.ibm.com> wrote in message
news:d6fneg$58v$1@news.eclipse.org...
> Hi
> analysis.
> Can anyone help?
> Regards
> Sarah Drewery
Previous Topic:WSDM and TPTP
Next Topic:How about the proposal of migrating TPTP features to RPT?
Current Time: Sun Aug 31 08:29:59 EDT 2025
Powered by FUDForum. Page generated in 0.02595 seconds
