Home » Modeling » Epsilon » EVL integration in UML2 Tools
EVL integration in UML2 Tools [message #17999] |
Tue, 12 May 2009 04:11  |
Originally posted by: arendt.mathematik.uni-marburg.de
Hi!
I want to integrate my EVL constraints into UML2 Tools but there is no
description (EpsilonBook, Cinema, ...) to do this.
Who can help me?
Thorsten
Re: EVL integration in UML2 Tools [message #18022 is a reply to message #18010] |
Tue, 12 May 2009 06:19   |
Hi Dimitris!
Thank you for your fast response.
I can execute the evl file via an EVL Validiation launch configuration
and the messages are shown in the validation view.
It works, but unfortunately there must be a mistake when launching: the
progress information shows an activity 'Loading models' and I think
there is an infinite loop!
Thorsten
Dimitris Kolovos schrieb:
> Hi Thorsten,
> A detailed tutorial for integrating EVL constraints with GMF editors is
> available in
> http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration. Ideally,
> like in the tutorial, you'd just need to write your constraints and bind
> them to with the UML2 namespace uri.
> However, it seems that validation is not enabled for the UML2 Tools
> (i.e. the Diagram menu doesn't have a Validate item). Let's see if we
> can get some help on this over at eclipse.modeling.mdt.uml2tools (added)
> Cheers,
> Dimitris
> Thorsten Arendt wrote:
>> Hi!
>> Who can help me?
>> Regards,
>> Thorsten
Re: EVL integration in UML2 Tools [message #18033 is a reply to message #18022] |
Tue, 12 May 2009 06:37   |
Hi Thorsten,
The reason for this is that once constraints have been evaluated, EVL
remains in a live state so that you can also invoke the available quick
fixes. If you don't need to invoke any quick fixes, you can click the
run-like arrow in the validation view and end the execution.
Dimitris
> Hi Dimitris!
> Thorsten
>> Hi Thorsten,
>> is available in
>> bind them to with the UML2 namespace uri.
>> Cheers,
>> Dimitris
>>> Hi!
>>> no description (EpsilonBook, Cinema, ...) to do this.
>>> Who can help me?
>>> Regards,
>>> Thorsten
Re: EVL integration in UML2 Tools [message #18046 is a reply to message #18033] |
Tue, 12 May 2009 06:43   |
Hi Dimitris!
I just found it out! Many Thanks.
> Hi Thorsten,
> Cheers,
> Dimitris
>> Hi Dimitris!
>> the progress information shows an activity 'Loading models' and I
>> think there is an infinite loop!
>> Thorsten
>>> Hi Thorsten,
>>> is available in
>>> Cheers,
>>> Dimitris
>>>> Hi!
>>>> Who can help me?
>>>> Regards,
>>>> Thorsten
Re: EVL integration in UML2 Tools [message #18059 is a reply to message #18046] |
Tue, 12 May 2009 09:05   |
Hi Thorsten,
Glad to hear that! However the UML2 Tools question remains: Is it
possible to somehow enable/invoke validation in the UML2 Tools GMF-based
editors or would one need to regenerate the editors with the right flags on?
Dimitris
> Hi Dimitris!
>> Hi Thorsten,
>> quick fixes. If you don't need to invoke any quick fixes, you can
>> click the run-like arrow in the validation view and end the execution.
>> Cheers,
>> Dimitris
>>> Hi Dimitris!
>>> configuration and the messages are shown in the validation view.
>>> Thorsten
>>>> Hi Thorsten,
>>>> is available in
>>>> Ideally, like in the tutorial, you'd just need to write your
>>>> constraints and bind them to with the UML2 namespace uri.
>>>> we can get some help on this over at eclipse.modeling.mdt.uml2tools
>>>> (added)
>>>> Cheers,
>>>> Dimitris
>>>>> Hi!
>>>>> Who can help me?
>>>>> Regards,
>>>>> Thorsten
Re: EVL integration in UML2 Tools [message #568165 is a reply to message #18010] |
Hi Dimitris!
Thorsten
> Hi Thorsten,
> available in
> http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration Ideally,
> Cheers,
> Dimitris
>> Hi!
>> Who can help me?
>> Regards,
>> Thorsten
Re: EVL integration in UML2 Tools [message #568193 is a reply to message #18022] |
Hi Thorsten,
Dimitris
> Hi Dimitris!
> Thorsten
>> Hi Thorsten,
>> is available in
>> Cheers,
>> Dimitris
>>> Hi!
>>> Who can help me?
>>> Regards,
>>> Thorsten
Re: EVL integration in UML2 Tools [message #568230 is a reply to message #18033] |
Hi Dimitris!
> Hi Thorsten,
> Cheers,
> Dimitris
>> Hi Dimitris!
>> Thorsten
>>> Hi Thorsten,
>>> is available in
>>> Cheers,
>>> Dimitris
>>>> Hi!
>>>> Who can help me?
>>>> Regards,
>>>> Thorsten
Re: EVL integration in UML2 Tools [message #568246 is a reply to message #18046] |
Hi Thorsten,
Dimitris
> Hi Dimitris!
>> Hi Thorsten,
>> Cheers,
>> Dimitris
>>> Hi Dimitris!
>>> Thorsten
>>>> Hi Thorsten,
>>>> is available in
>>>> (added)
>>>> Cheers,
>>>> Dimitris
>>>>> Hi!
>>>>> Who can help me?
>>>>> Regards,
>>>>> Thorsten
Re: EVL integration in UML Designer 6.0 [message #1735395 is a reply to message #568246] |
Sat, 18 June 2016 05:29  |
I like to use the EVL's live validation to check some constraints on a UML model. I'm using UML Design 6.0 and eclipse Mars. In other words, the validation must be triggered whenever a model is changed by the user. Following is my sample module:
context Class {
guard: self.name.isDefined()
constraint ClassNamesStartWithAnUpperCase{
check: self.name.firstToUpperCase() = self.name
message: "Each class name should start with an upper case letter!"
fix {
title: "Change " + self.name + " class name's first letter to an uppercase:"
do {
self.name = self.name.firstToUpperCase();
I used the tutorial of the following like:
http://www.eclipse.org/epsilon/doc/articles/evl-gmf-integration/
But, the live validation is not working for the UML Designer 6.0 class diagram editor which hosts my model, despite I clicked the Diagram>Validate menu!
Kind regards,
Alireza
Current Time: Sat Aug 30 23:27:03 EDT 2025
Powered by FUDForum. Page generated in 0.06635 seconds
