Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Product Build using existing config.ini
PDE Product Build using existing config.ini [message #17982] Wed, 27 August 2008 11:11 Go to next message
I having some trouble getting the PDE headless build to use an existing
'config.ini', instead it generates a default one. I have created a product
configuration and invoke the productBuild.xml via AntRunner. The entire
build process works without errros. However, the final product output does
not contain the custom 'config.ini'
I'm using Eclipse 3.4 Ganymede as my IDE and headless build environment.
The following is an excerpt from my .product definition:
<configIni use="default">
<linux>/features/org.sample.feature/configuration/config.ini </linux>
<macosx>/features/org.sample.feature/configuration/config.ini </macosx>
<solaris>/features/org.sample.feature/configuration/config.ini </solaris>
<win32>/features/org.sample.feature/configuration/config.ini </win32>
</configIni>
Any ideas on how to resolve this would be appreciated.
Re: PDE Product Build using existing config.ini [message #18700 is a reply to message #17982] Sat, 30 August 2008 12:07 Go to previous message
Hi Dennis,
Just noticed this looking for something else.
Mine looks like this and works when using the Export Product wizard.
<linux>/com.wwm.webservice.feature/config.ini</linux>
<macosx>/com.wwm.webservice.feature/config.ini</macosx>
<solaris>/com.wwm.webservice.feature/config.ini</solaris>
<win32>/com.wwm.webservice.feature/config.ini</win32>
</configIni>
In my case, the config.ini is in the same project as my .product file.
Neale
> </configIni>
Re: PDE Product Build using existing config.ini [message #577907 is a reply to message #17982] Sat, 30 August 2008 12:07 Go to previous message
Hi Dennis,
</configIni>
Neale
> </configIni>
Previous Topic:how to display log4j output in plugin console?
Next Topic:Unwanted plugin/bundle getting deployed (jetty 1.1.0 ticked, jetty 2.0.0 NOT, both deployed)
Current Time: Mon Jul 14 21:12:02 EDT 2025
Powered by FUDForum. Page generated in 0.05179 seconds
