Home » Eclipse Projects » Plugin Development Environment (PDE) » Use project source instead of jar?
Use project source instead of jar? [message #17969] Wed, 27 August 2008 09:36
Originally posted by: torbjorn.ghostwriter.no
I have a plugin project A that includes, uses and exports b.jar, which
contains the classes of the non-plugin project B. Changes made in project A
source, or any other plugin sources are hotswapped in the VM, and everything
is awesome. However, when making changes in plugin B, I have to stop the
application, compile b.jar and start the application again.
Is there a way to get the application to run using the source from project B
directly, but still use b.jar when exported and run outside of
thedevelopment environment?
Previous Topic:How to save information between the sessions of Eclipse?
Next Topic:Use project source instead of jar?
Current Time: Mon Jul 21 21:51:42 EDT 2025
Powered by FUDForum. Page generated in 0.05782 seconds
