Startup error after new install help needed (see log) [message #188748] |
Thu, 18 January 2007 05:58 |
Originally posted by: gruessle.gmail.com
I just installed eclipse on a Debian based system (Ubundu)
Following is my log file. Could you please take a look and tell me what it
means and what I need to do to get it working?
Thank you
Troy
# cat .log
!SESSION 2007-01-18 00:43:28.879
eclipse.buildId=M20060921-0945
java.version=1.5.0_08
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 2 1 2007-01-18 00:43:40.496
!MESSAGE NLS missing message: initializer_error in:
org.eclipse.core.internal.runtime.messages
!ENTRY org.eclipse.osgi 2 1 2007-01-18 00:43:40.497
!MESSAGE NLS missing message: fileInitializer_fileNotFound in:
!MESSAGE NLS missing message: fileInitializer_IOError in:
!MESSAGE NLS missing message: fileInitializer_missingFileName in:
!ENTRY org.eclipse.osgi 4 0 2007-01-18 00:43:41.135
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: memmove
at org.eclipse.swt.internal.gtk.OS.memmove(Native Method)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 67)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:126)
org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:433)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:75)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SESSION 2007-01-18 00:45:24.514
!ENTRY org.eclipse.osgi 2 1 2007-01-18 00:45:29.458
!ENTRY org.eclipse.osgi 2 1 2007-01-18 00:45:29.459
!ENTRY org.eclipse.osgi 2 1 2007-01-18 00:45:29.460
!ENTRY org.eclipse.osgi 4 0 2007-01-18 00:45:29.805
!STACK 1
FUDForum. Page generated in 0.09225 seconds
