Re: Grid - Cell Height [message #21026 is a reply to message #20439] |
Tue, 12 December 2006 10:56  |
I'm working on setItemHeight in Grid.
Naren wrote:
> Hi Chris,
> While I was trying to do this I noticed that
> void newItem(GridItem item, int index) {
> if (items.size() == 1)
> rowHeight = computeRowHeight(sizingGC);
> which means that rowHeight is based on row 1 and is computed once during
> the creation and cannot be changed later
> say, If I create
> class MyTable extends Grid
> and still cannot override either
> newItem (package access)
> computeRowHeight (private)
> rowHeight (private)
> In my case, I need to set the itemheight if the shell is resized (all
> the rows will be of same height). I tried to change font height to
> reflect this, font in the table changes but not the item height.
> Please, let me know if there is any other way to reflect this behavior.
> Thanks
> Naren
> Chris Gross wrote:
>> This is currently only possible if you write your own custom cell
>> renderer.
>> -Chris
>> Naren wrote:
>>> How to set cell height in Grid?
>>> Naren
Re: Grid - Cell Height [message #572644 is a reply to message #17963] |
Tue, 12 December 2006 10:53  |
Hi Chris,
say, If I create
rowHeight (private)
In my case, I need to set the itemheight if the shell is resized (all the
rows will be of same height). I tried to change font height to reflect
Naren
Chris Gross wrote:
> This is currently only possible if you write your own custom cell renderer.
> -Chris
>> Naren
Re: Grid - Cell Height [message #572705 is a reply to message #20439] |
Naren wrote:
> Hi Chris,
> say, If I create
> rowHeight (private)
> Thanks
> Naren
>> renderer.
>> -Chris
>>> Naren
FUDForum. Page generated in 5.14045 seconds
