Generating BIRT report from Java/JSP application [message #188570] |
Thu, 31 August 2006 08:14  |
I am working on an Java(jsp)/JBoss/SqlServer application that will be used
entirely in house and would like to use BIRT to generate pre-designed
reports that the user can run using a button on the GUI(jsp button click
event) and see the appropriate records. The SQL is already generated in
the application.
I have installed BIRT and the Eclipse plug-in. I was able to generate a
basic report, set a data link and display the report from within Eclipse.
There are two things I still need to accomplish which are very closely
related and I am having difficulties solving them.
1. Running the pre-created report from the Java code. I was thinking of
generating a PDF so it could be saved and easily shared with other people
through email. I would like to avoid deploying out to a web server if at
all possible. I just want to the user to click the "view" button and have
the application generate a PDF based onthat they can then save, print or
do whatever they want with it.
2. When the user clicks the view button I want to generate the report with
the proper data using the logic of the program flow to determine what the
user wants. As I mentioned I am already hitting the database to display
the record in a JTable. All I need to do is generate the report with the
same data.
I have searched around and I only find information on creating web pages
or viewing from eclipse. Any direction or advice would be greatly
appreciated.
Re: Generating BIRT report from Java/JSP application [message #188593 is a reply to message #188578] |
Thu, 31 August 2006 08:49   |
Hi gurumoothy,
Thanks for responding for my query.
I have downloaded the birt-runtime and put the plugin and configuration
folders in the buildpath of eclispe since i'm using eclipse to deploy my
appln.
but when i click the button(jsp button action) for calling a java file,
i'm getting a null pointer exception since my platform is not yet started.
This is my java code..
package com.bmw.bbemails.test;
import java.util.HashMap;
import java.util.logging.Level;
import javax.servlet.*;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.PlatformServletContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.impl.ReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;/*
public class Test {
public void test() throws EngineException
HashMap<String, Integer> parameters = new HashMap<String, Integer>();
String name = "Top Count";
Integer pvalue = new Integer(4);
parameters.put(name, pvalue);
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setEngineHome(
"K:/eclipse_projects/bbemails/web/WEB-INF/lib/plugins" );
config.setLogConfig("s:/birt/logs", Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_EN GINE_FACTORY
engine = factory.createReportEngine(config);
engine.changeLogLevel( Level.WARNING );
}catch( Exception ex){
ex.printStackTrace();
IReportRunnable design = null;
//Open the report design
design =
engine.openReportDesign("K:/eclipse_projects/bbemails/web/Report.rptdesign ");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
//Set the Base URL for all actions
renderContext.setBaseURL("http://localhost:8080/bbemails/");
//Tell the Engine to prepend all images with this URL - Note this
requires using the HTMLServerImageHandler
renderContext.setBaseImageURL("http://localhost:8080/bbemails/web");
//Tell the Engine where to write the images to
renderContext.setImageDirectory("s:/birt/logs");
//Tell the Engine what image formats are supported. Note you must have
SVG in the string
//to render charts in SVG.
renderContext.setSupportedImageFormats("JPG;PNG;BMP;SVG");
HashMap<String, HTMLRenderContext> contextMap = new HashMap<String,
HTMLRenderContext>();
contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( contextMap );
//Set parameters for the report
task.setParameterValues(parameters);
//Alternatively set each seperately
//task.setParameterValue("Top Count", new Integer(12));
task.validateParameters();
//Add a scriptable object, which will allow the report developer to put
//script in the report that references this Java object. eg in script
//pFilter.myjavamethod()
//ProcessFilter pf = new ProcessFilter();
//task.addScriptableJavaObject("pFilter", pf);
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
//Remove HTML and Body tags
options.setEmbeddable(true);
//Set ouptut location
options.setOutputFileName("s:/birt/logs");
//Set output format
options.setOutputFormat("html");
task.setRenderOption(options);
//run the report and destroy the engine
//Note - If the program stays resident do not shutdown the Platform or
the Engine
task.run();
task.close();
engine.shutdown();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
catch ( Exception e )
e.printStackTrace();
if this is not the correct way, could u please help me solve this problem?
manuel
Re: Generating BIRT report from Java/JSP application [message #188684 is a reply to message #188593] |
Thu, 31 August 2006 09:58   |
Originally posted by: eldude23.hotmail.com
I had a similar problem... if you (as I did) copied your ReportEngine
directory to "X:/..../lib", try changing...
to
config.setEngineHome( "K:/eclipse_projects/bbemails/web/WEB-INF/lib" );
Roger
"Manuel" <usha.manuel@mybdr.com> wrote in message
news:150a27075c6c0eca22868d356ec8bf4c$1@www.eclipse.org...
> Hi gurumoothy,
> appln.
> public class Test {
> try{
> createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_EN GINE_FACTORY );
> design =
> //Tell the Engine to prepend all images with this URL - Note this requires
> SVG in the string //to render charts in SVG.
> renderContext );
> //Set rendering options - such as file or stream output, //output format,
> //Set output format
> //Note - If the program stays resident do not shutdown the Platform or the
> Engine
> task.run();
> task.close();
> engine.shutdown();
> * @param args
> public static void main(String[] args) {
> try
> manuel
FUDForum. Page generated in 0.05292 seconds
