GDB - Breakpoint never trigered [message #188517] |
Fri, 30 March 2007 12:05 |
Hi all,
I would wish to use gdb under eclipse/cdt.
My configuration:
Eclipse 3.2.1
CDT 3.1.2
MinGW 5.1.3
Mingw32-make 3.81
GDB 5.2.1
OK. I have write a plugin which makes it possible to create
managedprojects and some other features. Many thanks to Derek for that,
which helped me much. :-)
The managed project consists in creating a Window's DLL which is used by a
front-end application.
All is ok. The front-end uses my DLL.
Now, I wish to use GDB for the development of the DLL.
I do not find a functional configuration. I tested several versions of
GDB (all versions greater than 5.2.1 crash when a breakpoint is trigered),
I tested all the options offered by the Debug->C/C++ Local
Application->... dialog boxes.
I do not have the symbols of the front-end. I thus use a .gdbInit file to
place a breakpoint in the DLL:
> dll-symbols my.dll
> b my.cpp: 55
On the Debug configuration, "Main" tab, I indicate the frontend.exe.
On the "debugger" tab, I indicate the GDB command file (.gdbInit), and I
tested all the choices.
I got a dialog box : "Error stopping at main.... Continue?"
OK, there is no symbol for the front-end... I answer yes.
The front-end run...
The DLL run...
But the breakpoint is never trigered.
Any idea?
Philippe
FUDForum. Page generated in 0.28790 seconds
