Home » Language IDEs » Java Development Tools (JDT) » Why directory structure is enforced?
Why directory structure is enforced? [message #188514] Fri, 03 December 2004 17:34 Go to next message
Hi! Here's the problem. I'm writing code that belongs to the package, say,
"com.company.project.util".
And I want to keep this code in CVS directory, say,
/src/project/util/java. And I want to put all .java files right there in
this directory, without that nested directory tree
"com/company/project/util".
Eclipse doesn't like that. It gives me the error "The declared package
does not match the expected package com.company.project.util".
IS there any way to fix that? Do Eclipse developers plan to allow
arbitrary source paths?
Andrew
Re: Why directory structure is enforced? [message #188541 is a reply to message #188514] Fri, 03 December 2004 23:03 Go to previous messageGo to next message
> say, "com.company.project.util".
It's worked like this in Java since version 1. (Of Java!)
Get used to it.
Alex
Re: Why directory structure is enforced? [message #188555 is a reply to message #188541] Sat, 04 December 2004 20:41 Go to previous messageGo to next message
It seems to me that java works like it for class files, not for source
files. If I remember well the time when I used javac and a plain text
editor, my source files could all be in the same directory but belong to
different packages.
>> in this directory, without that nested directory tree
> Get used to it.
Re: Why directory structure is enforced? [message #188562 is a reply to message #188555] Sat, 04 December 2004 22:09 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
hi Guillaume,
yes - you are correct in that when using the 'javac' command-line tool, all your
sources could be located in same directory. But, afaik, physically separating
them based on the package structure allows for lot easier maintenance. Eclipse
just enforces this as a rule.
HTH,
Vijay
> different packages.
>>> package does not match the expected package com.company.project.util".
>> Get used to it.
Re: Why directory structure is enforced? [message #188576 is a reply to message #188555] Sun, 05 December 2004 15:40 Go to previous message
Originally posted by: not_real.not_real.com
This is not entirely true. In order for javac to be able to
automatically find and compile other java classes that a file depends
on, it relies on a sourcepath directory structure that matches the
package structure.
> different packages.
>> Get used to it.
Previous Topic:Code generation
Next Topic:debuggee - debugger communication in eclipse
Current Time: Mon Jul 14 00:15:01 EDT 2025
Powered by FUDForum. Page generated in 0.03467 seconds
