Home » Eclipse Projects » Eclipse Website » top Navbar tabs
Re: top Navbar tabs [message #17938 is a reply to message #17925] |
Thu, 22 June 2006 13:55   |
Hi Denis,
Yeah I was testing my pages locally, that's why I had the url to the C
directory. I updated them and everything's working fine.
Haytham
"Eclipse WebMaster (Denis Roy)" <webmaster@eclipse.org> wrote in message
news:e7e5i9$lm1$1@utils.eclipse.org...
> Here are some thoughts:
> 1. Your CSS files have local paths:
http://download.eclipse.org/eclipse/downloads/drops/I2006062 0-1010/test/stylesheets/visual.css
> #header {
> background-image: url(C:/junk/header_bg.gif);
> background-position: top left;
> background-repeat: repeat-x;
> #searchbar {
> background-image: url(C:/junk/searchbar_bg.gif);
> 2. The same stylesheet has URLs that are relative to www.eclipse.org,
> but because you're running this on download.eclipse.org (and the various
> IBM fullmoons), they don't work:
> background-image:
> url(/eclipse.org-common/themes/Phoenix/images/leftnav_bullet .gif);
> 3. I'd highly recommend not placing eclipse.org-common, nor your
> stylesheets inside the build directory, as you'll be duplicating a whole
> bunch of files for each build, and fixing an issue with the page layout
> will be a time-consuming chore.
> D.
> Haytham Yassine wrote:
> > Hi, I can't manage to seperate my top Navbar list into tabs as in the
> > eclipse.org main page. I tried copying the whole code of the eclipse.org
> > page to try and see if the tabs appear correctly and it didn't work
either.
> > Do you have any idea about what might be causing this?
> > http://fullmoon.ottawa.ibm.com/downloads/drops/I20060620-101 0/test/
> > -Haytham Y.
> Eclipse WebMaster - webmaster@eclipse.org
> Questions? Consult the WebMaster FAQ at
> http://wiki.eclipse.org/index.php/Webmaster_FAQ
> View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: top Navbar tabs [message #17951 is a reply to message #17925] |
Thu, 06 July 2006 09:50   |
Denis,
What approach would you suggest for people who need to use the Phoenix
code on a local mirror? Copy it to a central location on the mirror.
In the php, set a condition that if the hostname is not eclipse.org, use
the copy, otherwise point to the eclipse.org version?
Kim
that people use who need to use the Phoenix code on a local mirror an
> #header {
> #searchbar {
> background-image:
> D.
>> either.
>> -Haytham Y.
Re: top Navbar tabs [message #17965 is a reply to message #17951] |
Fri, 07 July 2006 16:02  |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
I would suggest you install eclipse.org-common (from CVS) into
/eclipse/downloads, so that all your drops/ directories can reference
it. Keep your references relative (../../ etc) and this should all work
fine on mirror sites.
D.
Kim Moir wrote:
> Denis,
> code on a local mirror? Copy it to a central location on the mirror. In
> Kim
>> #header {
>> #searchbar {
>> various IBM fullmoons), they don't work:
>> background-image:
>> whole bunch of files for each build, and fixing an issue with the page
>> layout will be a time-consuming chore.
>> D.
>>> either.
>>> -Haytham Y.
Re: top Navbar tabs [message #569848 is a reply to message #17925] |
Hi Denis,
Haytham
> #header {
> #searchbar {
> background-image:
> D.
either.
> > -Haytham Y.
Re: top Navbar tabs [message #569868 is a reply to message #17925] |
Denis,
Kim
> #header {
> #searchbar {
> background-image:
> D.
>> either.
>> -Haytham Y.
Re: top Navbar tabs [message #569893 is a reply to message #17951] |
D.
Kim Moir wrote:
> Denis,
> Kim
>> #header {
>> #searchbar {
>> background-image:
>> D.
>>> either.
>>> -Haytham Y.
Current Time: Thu Jul 17 19:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.10243 seconds
