Home » Language IDEs » Java Development Tools (JDT) » needs code snippet for ICompilationUnit javadoc promise
needs code snippet for ICompilationUnit javadoc promise [message #188187] |
Thu, 02 December 2004 10:48  |
Originally posted by: edoardoATenigmatecDOTnet.no.spam
I previously posted on the same problem but can't find an answer.
I'd need to see a code snippet that does what the following javadox
promises : creating an ICompilationUnit on an not-yet-existing one
my attempts so far fail - to me it seems I need to create the resource
BEFORE I commit.
TIA,
Edo
package org.eclipse.jdt.core;
public interface ICompilationUnit ...
* Since 2.1, a working copy can be created on a not-yet existing
compilation
* unit. In particular, such a working copy can then be committed in
order to create
* the corresponding compilation unit.
void commitWorkingCopy(boolean force, IProgressMonitor monitor) throws
JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188400 is a reply to message #188392] |
Fri, 03 December 2004 07:52   |
Thanks Jerome!
can you confirm that there is currently no way to open an editor on such
a compilation unit ?
if you think it would be reasonable to implement such a request, I'll
enter it into bugzilla
My rationale is that my plugin provides an editor for a 'domain object'
which has some details implemented by java classes.
As long as the editor is dirty, ie manipulating a domain object in
memory, I would be happy to keep the ICompilationUnits in memory as well,
and commit (or discard them) all when the editor is saved (or closed
without saving, respectively).
Edo
Jerome Lanneluc wrote:
> You can have a look at the Java model test:
> org.eclipse.jdt.core.tests.model.WorkingCopyTests#testNonExi stingCu().
> HTH,
> Jerome
> "Edoardo Comar" <edoardoATenigmatecDOTnet@no.spam> wrote in message
> news:condg0$n3m$1@www.eclipse.org...
>>Hi
>>BEFORE I commit.
>>TIA,
>>Edo
>>compilation
>>order to create
>>JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188417 is a reply to message #188400] |
Fri, 03 December 2004 08:46   |
I'm not in the editor business, but I would expect to be able to open an
editor on such a compilation unit.
What makes you say that it is not possible ? Do you get any exception when
attempting to open an editor on such a compilation unit ?
Jerome
news:copnhk$ne7$1@www.eclipse.org...
> Thanks Jerome!
> Edo
> > HTH,
> > Jerome
> >>Hi
> >>BEFORE I commit.
> >>TIA,
> >>Edo
> >>compilation
> >>order to create
> >>JavaModelException;
Re: needs code snippet for ICompilationUnit javadoc promise [message #188450 is a reply to message #188417] |
Fri, 03 December 2004 10:11  |
--------------000605070300070901080803
The exception is ... "File does not exist" (surprise :-)
here is attached an action that you can declare in an action set and try
I'm submitting the issue to bugzilla
Edo
> Jerome
>>Thanks Jerome!
>>Edo
>>>HTH,
>>>Jerome
>>>>Hi
>>>>BEFORE I commit.
>>>>TIA,
>>>>Edo
>>>>compilation
>>>>order to create
>>>>JavaModelException;
Content-Type: text/x-java;
name="TestActionSetAction2.java"
Content-Disposition: inline;
filename="TestActionSetAction2.java"
* @(#)$Id: TestActionSetAction2.java,v 1.2 2004/12/03 09:54:41 edoardo Exp $
* Confidential Licenced Materials of Enigmatec Corporation.
* Copyright Enigmatec Corporation @ 2004
package com.enigmatec.emsj.test.visualinspection;
import java.io.PrintWriter;
import java.io.StringWriter;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.jdt.ui.JavaUI;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.ErrorDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IWorkbenchWindowActionDelegate;
* It creates a new non existing Java ICompilationUnit working copy in the same package as the currently
* open java editor and then attempts to open an editor on it.
* <p>
* This action can be contributed by an action set.
* </p>
* <pre>
* <extension
point="org.eclipse.ui.actionSets">
<actionSet
label="TESTactionSet"
visible="true"
id="visualinspection.actionSets.ID">
<action
label="TASA2"
class=" com.enigmatec.emsj.test.visualinspection.TestActionSetAction 2 "
tooltip="actionSets Visual inspection test2"
toolbarPath="testpath"
id="visualinspection.actionSets.actionTEST.ID2">
</action>
</actionSet>
</extension>
* </pre>
* @author Edoardo Comar <edoardo.NOSPAM@NOSPAM.enigmatec.net>
public class TestActionSetAction2 implements IWorkbenchWindowActionDelegate {
private IWorkbenchWindow window;
private ISelection selection;
public TestActionSetAction2() {
super();
* the guts of the action
protected void runWithException(IAction action) throws Exception {
IEditorPart editorPart = getWorkbenchWindow().getActivePage().getActiveEditor();
if (editorPart == null) {
return;
IEditorInput editorInput = editorPart.getEditorInput();
IResource resource = (IResource) editorInput.getAdapter(IResource.class);
if (resource == null) {
return;
ICompilationUnit icu = JavaCore.createCompilationUnitFrom((IFile) resource);
if (icu == null) {
return;
IPath icuPath = icu.getPath();
IPath nonExistingCUPath = icuPath.removeLastSegments(1).addTrailingSeparator().append(
"Foo.java");
IFile nonExistingFile = resource.getWorkspace().getRoot().getFile(nonExistingCUPath) ;
System.out.println(nonExistingFile);
ICompilationUnit nonExistingCU = JavaCore.createCompilationUnitFrom(nonExistingFile);
ICompilationUnit workingCopy = nonExistingCU.getWorkingCopy(null);
workingCopy.getBuffer().setContents("public class Foo {\n }\n");
System.out.println(workingCopy);
JavaUI.openInEditor(workingCopy);
* (non-Javadoc)
* @see org.eclipse.ui.IActionDelegate#run(org.eclipse.jface.action. IAction)
public void run(IAction action) {
try {
runWithException(action);
} catch (Exception e) {
StringWriter sw = new StringWriter();
e.printStackTrace(new PrintWriter(sw));
String smallStackTrace = sw.toString().substring(0, Math.min(sw.toString().length(), 500));
ErrorDialog.openError(window.getShell(), "ERROR", e.getMessage(), new Status(IStatus.ERROR,
"your-plugin-id", IStatus.ERROR, smallStackTrace, e));
/* (non-Javadoc)
* @see org.eclipse.ui.IActionDelegate#selectionChanged(org.eclipse. jface.action.IAction, org.eclipse.jface.viewers.ISelection)
public void selectionChanged(IAction action, ISelection selection) {
this.selection = selection;
/* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchWindowActionDelegate#dispose()
public void dispose() {
window = null;
selection = null;
/* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchWindowActionDelegate#init(org.eclip se.ui.IWorkbenchWindow)
public void init(IWorkbenchWindow window) {
this.window = window;
protected IWorkbenchWindow getWorkbenchWindow() {
return window;
protected ISelection getSelection() {
return selection;
--------------000605070300070901080803--
Current Time: Wed Jul 23 10:41:13 EDT 2025
Powered by FUDForum. Page generated in 0.03506 seconds
