Home » Eclipse Projects » GEF » Refreshing Images
Refreshing Images [message #188150] Tue, 19 July 2005 08:35 Go to next message
Originally posted by: jimMolk.none.ro
I have created a GUI with several editparts,models,etc...using draw2d and
GEF.
Each Editparts has its own figure
My problem is when i try to chande dynamically one selected figure by
changing its image (figure.getImage().setImage(Image)) , the image get
changed but it does not show at screen : to see the change i have to
select another figure : then the changed image appears.
i tried several methods like repaint,revalidate,etc...but no changes
any idea ?
thxs for help
Re: Refreshing Images [message #188199 is a reply to message #188150] Tue, 19 July 2005 11:17 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Figure.setImage() should invoke repaint() when the image is changed. That
should do it. Look at ImageFigure#setImage() for reference. It invokes
revalidate, but that is only because the image's size could be different and
the figure might have to be laid out again.
If this is not working for you, post some code or explanation about when
you're changing the figure's image.
"Jim Molk" <jimMolk@none.ro> wrote in message
news:e6af4b4ddc068338dbcd44f13592061c$1@www.eclipse.org...
> Hi
> GEF.
> any idea ?
> thxs for help
Re: Refreshing Images [message #188260 is a reply to message #188199] Tue, 19 July 2005 11:58 Go to previous messageGo to next message
Originally posted by: jimmolk.none.ro
Thxs but it doesn't work
here is my code :
I have several ComponentModels associated to their ComponentEditParts
*in class ComponentEditPart :
protected IFigure createFigure() {
ComponentModel model = (ComponentModel) getModel();
ComponentFigure figure = new ComponentFigure(model.getState());
model.setConstraint(new
Rectangle(figure.getLocation(),figure.getSize()));
return figure;
// called when a user made an action on the Component : State has changed
and Component's imageFigure has to change too
public void propertyChange(PropertyChangeEvent evt) {
if (evt.getPropertyName().equals(ComponentModel.P_STATE)) {
refreshFigure();
// call setImg of ComponentFigure
public void refreshFigure() {
((ComponentFigure) this.getFigure()).setImg(((ComponentModel)
getModel()).getState().getImage());
*Class componentFigure :
public class ComponentFigure extends Panel {
public final static int P_WIDTH = 62;
public final static int P_HEIGHT = 58;
private FixedSizeLabel label = new FixedSizeLabel(62);
private State state;
private ImageFigure imgfig;
private FlowLayout fl ;
public ComponentFigure(State state) {
this.state= state;
fl = new FlowLayout(false);
fl.setMinorAlignment(FlowLayout.ALIGN_CENTER);
fl.setMinorSpacing(0);
this.setLayoutManager(fl);
Image img = state.getImage();
imgfig = new ImageFigure();
imgfig.setImage(img);
this.setPreferredSize(P_WIDTH,P_HEIGHT);
this.setSize(P_WIDTH,P_HEIGHT);
this.add(imgfig);
this.add(label);
public void setName(String name) {
label.setText(label.getSubStringText(name));
label.setFont(new Font(null,"MS Sans Serif",8,0));
label.setToolTip(new Label(name));
//called when image has changed
public void setImg(Image arg) {
imgfig.setImage(arg);
So when i select a Component and make an action on it, there's no change
on screen though image has changed
i have to select another component,or for exemple minimize eclipse and
maximize it to make changes appear on screen...
Thxs for help !
Re: Refreshing Images [message #188284 is a reply to message #188260] Tue, 19 July 2005 13:31 Go to previous messageGo to next message
"Jim Molk" <jimmolk@none.ro> wrote in message
news:85e99629b92c55d1911b966ad0899950$1@www.eclipse.org...
> here is my code :
Shouldn't it be the other way around? The figure's size to be retrieved
from the model?
> return figure;
> refreshFigure();
Any reason for not using refreshVisuals()?
You probably should use figure rather than panel.
> this.state= state;
> this.add(imgfig);
> this.add(label);
Resource leak.
I'm not sure why this is not working for you. Try to see if
ImageFigure#paintFigure() is being called after you set the image.
> Thxs for help !
Re: Refreshing Images [message #188375 is a reply to message #188284] Wed, 20 July 2005 05:22 Go to previous messageGo to next message
Thxs a lot ! i think i know where the problem is : it may be the device
parameter...why does a null parameter causes a memory leak in
label#setFont(); ?
I load my image like this : Image img = new Image(null,
MyEditor.class.getResourceAsStream(image))
in org.eclipse.swt.graphics.Image.java :
public Image (Device device, InputStream stream) {
if (device == null) device = Device.getDevice();
if (device == null) SWT.error(SWT.ERROR_NULL_ARGUMENT);
init(device, new ImageData(stream));
if (device.tracking) device.new_Object(this);
I tried to catch exceptions for ImageFigure#setImg() :
try {
} catch(Exception e) {
e.printStackTrace();
Then i got a NullPointerException:
org.eclipse.draw2d.DeferredUpdateManager.queueWork(DeferredU pdateManager.java:151)
org.eclipse.draw2d.DeferredUpdateManager.addInvalidFigure(De ferredUpdateManager.java:101)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1221)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1223)
in org.eclipse.draw2d.DeferredUpdateManager :
queueWork() {
if (!updateQueued) {
Display.getCurrent().asyncExec(new UpdateRequest());
updateQueued = true;
So what should i put instead of null parameter for device ?
thxs for your help
>> here is my code :
> from the model?
->nevermind, this line had no use.
>> return figure;
>> refreshFigure();
-> i used refreshVisuals but that didn't work
->i tried , no changes
Re: Refreshing Images [message #188859 is a reply to message #188375] Fri, 22 July 2005 15:26 Go to previous message
It's not the null parameter that is the resource leak. It's the font that
you're creating and not disposing.
That, however, is not what's causing this problem. From your stack trace,
it seems you're setting the new image for the figure from outside the UI
thread. That's not allowed. Use Display.a/syncExec().
news:fade893b4998b9f342ef0d71a4a883ba$1@www.eclipse.org...
> label#setFont(); ?
> try {
> java.lang.NullPointerException
> at
a:151)
> at
ger.java:101)
> queueWork() {
> thxs for your help
> >> here is my code :
> > from the model?
> >> return figure;
changed
> >> refreshFigure();
Previous Topic:PropertiesView based on EMF.edit Framework
Next Topic:opening a second editor
Current Time: Thu Jul 24 15:44:33 EDT 2025
Powered by FUDForum. Page generated in 0.06254 seconds
