NOEXEC error libpiAgent.so for tomcat 5.0 in AIX 5.1 64bit. [message #17837] |
Fri, 06 May 2005 15:27  |
Originally posted by: rayli.hotmail.com
I try to start up the tomcat 5.0 with the following setting:
export JPDA_TRANSPORT=dt_socket
export JPDA_ADDRESS=8000
export LIBPATH=/home/qasys2/raserver/lib
export JAVA_OPTS='-Xms100M -Xmx200M -XrunpiAgent:server=enabled'
but it failed in error "Can't load "libpiAgent.so", because load ENOEXEC on
shared library(s) /home/qasys2/raserver/lib/libpiAgent.so
xmloadJVMHelperLib piAgent server=enabled, failed
Could not create the Java virtual machine."
Does anyone have this problem? is it something to do with 64bit JRE
my java version:
java version "1.4.1"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.1)
Classic VM (build 1.4.1, J2RE 1.4.1 IBM AIX 5L for PowerPC (64 bit JVM)
build caix64141-20030703a (JIT enabled: jitc))
Re: NOEXEC error libpiAgent.so for tomcat 5.0 in AIX 5.1 64bit. [message #17904 is a reply to message #17850] |
Wed, 11 May 2005 14:39  |
Hi Ray,
I am guessing you are using the same machine to run both 32-bit and 64-bit
JVM, right?
The piAgent is not ported to 64-bit AIX yet. The one available from
Eclipse.org is a 32-bit compiled version. A 64-bit version is in plan for
future release.
Samson
"raymond" <rayli@hotmail.com> wrote in message
news:d5gi8m$osl$1@news.eclipse.org...
> When I use Java 1.3 32bit, it works.
> java version "1.3.1"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.3.1)
> Classic VM (build 1.3.1, J2RE 1.3.1 IBM AIX build ca131-20021107 (JIT
> enabled: jitc))
> news:d5ggs8$n8c$1@news.eclipse.org...
ENOEXEC
> on
> > my java version:
FUDForum. Page generated in 0.04566 seconds
