Home » Archived » Visual Editor (VE) » having install problems with VE
having install problems with VE [message #17817] Wed, 04 February 2004 20:46 Go to next message
Originally posted by: zeitgeist45'spammano'.hotmail.com
hi-
I have GEF and EMF installed, I put the necessary files into /plugins and /features, but VE won't run. Also, org.eclipse.jem and org.eclipse.ve are not showing up in feature details. If anyone can clue me into what else I need to do, that would be helpful. thanks
Re: having install problems with VE [message #18120 is a reply to message #17817] Thu, 05 February 2004 08:58 Go to previous messageGo to next message
Do you get any errors in the .log file that indicates missing plugins? or
anything else that might be relevant to the org.eclipse.jem and
org.eclipse.ve plugins?
Also... which driver did you try to install? The 0.5.0 driver is stable but
runs on Eclipse 2.1.2.
The latest build (N20040113) is a nightly build and is work in progress
based on Eclipse build 3.0M5. The GEF and EMF plugins must be the ones
specified for each build.
Regards....
Peter Walker
"SCase" <zeitgeist45'spammano'@hotmail.com> wrote in message
news:bvs75p$60t$1@eclipse.org...
> hi-
Re: having install problems with VE [message #18149 is a reply to message #18120] Thu, 05 February 2004 10:13 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Also, please add what version of VE, Eclipse, GEF, EMF and on what OS
are you running?
Thanks, Rich Kulp
Re: having install problems with VE [message #18285 is a reply to message #18149] Tue, 10 February 2004 02:34 Go to previous messageGo to next message
Originally posted by: Aisling.Vasey.intec.co.za
I am having similar problems. I tried installing:
Eclipse SDK 3.0 M5
EMF 2.0.0 20031219_0637VL
GEF runtime I20040108 and then tried GEF SDK I20040108
and
VE runtime IM520040206 and also tried VE runtime IM520040209a
OS is XP.
None of the plug-ins are visible in the feature window.
> are you running?
Re: having install problems with VE [message #18301 is a reply to message #18285] Tue, 10 February 2004 11:12 Go to previous messageGo to next message
Anything in the .log file?
Thanks, Rich Kulp
Re: having install problems with VE [message #18318 is a reply to message #18285] Tue, 10 February 2004 11:12 Go to previous messageGo to next message
You may want to double check the plugin directories in Windows Explorer to
be sure the files were unzipped to the correct directories. The zip file
structure for Eclipse SDK is eclipse\... whereas the zip file structure for
all others (i.e. GEF, EMF, VE) is features\... and plugins\...
Regards...
Peter Walker
"Aisling Vasey" <Aisling.Vasey@intec.co.za> wrote in message
news:c0a1ht$ccr$1@eclipse.org...
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
> Thanks
> > are you running?
Re: having install problems with VE [message #18335 is a reply to message #18285] Tue, 10 February 2004 12:00 Go to previous messageGo to next message
Originally posted by: jdm0532.nospam.cs.rit.edu
Have you activated the plugins in your Product Configuration? In Eclipse
3.0 installing plugins isn't as straight forward as dropping the files
in the directory as it was in 2.x. Go to Help->Software Updates->Manage
Configuration. There should be a link there for something like
"Activate new plugins" that will enable the new features.
- Jeff
Aisling Vasey wrote:
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
Re: having install problems with VE [message #18352 is a reply to message #18285] Tue, 10 February 2004 18:41 Go to previous messageGo to next message
Originally posted by: buamar.iai.uni-bonn.de
"Aisling Vasey" <Aisling.Vasey@intec.co.za> schrieb im Newsbeitrag
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
I had similar problems. I solved the problems by changing the name of the
folder where i installed eclipse.
It seems thats Eclipse 3.0 M5 etc registrates new features/ plugins only
after the path of its own directory changes.
This is strange but it solved the problem. I tried it several times. The
log-file says nothing.
I used the same versions and the same OS as Aisling Vasey (see above).
Rachid Buamar
Re: having install problems with VE [message #19359 is a reply to message #18352] Wed, 18 February 2004 09:04 Go to previous message
I did a totally new install of the same versions of Eclipse M5, EMF, GEF
and VE and then only started Eclipse for the first time and now the
plug-ins are visible and working with no additional configurations
necessary.
Not sure why this is the case but it works now.
Aisling
> > Hi
> > Eclipse SDK 3.0 M5
> > and
> > OS is XP.
> Rachid Buamar
Re: having install problems with VE [message #580274 is a reply to message #17817] Thu, 05 February 2004 08:58 Go to previous message
Regards....
Peter Walker
> hi-
Re: having install problems with VE [message #580335 is a reply to message #18120] Thu, 05 February 2004 10:13 Go to previous message
are you running?
Thanks, Rich Kulp
Re: having install problems with VE [message #580595 is a reply to message #18149] Tue, 10 February 2004 02:34 Go to previous message
Eclipse SDK 3.0 M5
and
OS is XP.
> are you running?
Re: having install problems with VE [message #580630 is a reply to message #18285] Tue, 10 February 2004 11:12 Go to previous message
Thanks, Rich Kulp
Re: having install problems with VE [message #580642 is a reply to message #18285] Tue, 10 February 2004 11:12 Go to previous message
Regards...
Peter Walker
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
> Thanks
> > are you running?
Re: having install problems with VE [message #580661 is a reply to message #18285] Tue, 10 February 2004 12:00 Go to previous message
- Jeff
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
Re: having install problems with VE [message #580698 is a reply to message #18285] Tue, 10 February 2004 18:41 Go to previous message
> Hi
> Eclipse SDK 3.0 M5
> and
> OS is XP.
Rachid Buamar
Re: having install problems with VE [message #581395 is a reply to message #18352] Wed, 18 February 2004 09:04 Go to previous message
necessary.
Aisling
> > Hi
> > Eclipse SDK 3.0 M5
> > and
> > OS is XP.
> Rachid Buamar
Previous Topic:Problem running VE 0.5.0
Next Topic:Managing Imports
Current Time: Sat Jul 12 17:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.04977 seconds
