Versoins that can be used [message #187673] |
Thu, 11 January 2007 10:40 |
Conor Missing name Messages: 159 Registered: July 2009 |
I'm relatively new to Eclipse so am not too familiar with versions of
releases, etc.
I want to use a plugin that uses OCL, the version that is specified is EMF
OCL build 1.1M3, from the download page:
http://www.eclipse.org/emft/downloads/index.php?project=ocl& amp;showAll=0&showMax=5
all I can see is the M4 and M2 builds. Can I safely use a build that is
higher than the one specified? i.e. M4 instead of M3
If so, is this also true in general for builds etc in Eclipse?
To use a higher version than is specified? In terms of Maintenance
releases that is. As I understand it it is much more important to be very
specific when it comes to the number.number.number versions, but possibly
less so when it comes to maintenance builds?
Thanks, Gaff
FUDForum. Page generated in 0.09055 seconds
