Home » Archived » Visual Editor (VE) » About MemberJavaBeanCellEditor class...
About MemberJavaBeanCellEditor class... [message #17804] Wed, 04 February 2004 09:00
Hi!
I changed the border.override file to show variable names of border type
instead open the border editor dialog. To do this, I use the
MemberJavaBeanCellEditor in the .override file.
Now, I need to show in the variables border list the java dafault borders
too.
I've seen that this class uses two list (javaObjects and
javaObjectsLabels).
After the 'while' instruction in the 'setSources' method I added this line:
javaObjectLabels.add("new javax.swing.border.BevelBorder(2)");
With this, the properties sheet shows me my border type variables and 'new
javax.swing.border.BevelBorder(2)' too.
But, only with this VE do nothing if I select the last option.
I supposed that I need add an object to the 'javaObjects' list.
I believe that I must add an IJavaObjectInstance object but I don''t know
what methods must implements and... what must they return?
Many thanks.
Previous Topic:VE: More about 'get methods' when I select a variable for a property.
Next Topic:About MemberJavaBeanCellEditor class...
Current Time: Sat Aug 30 21:05:11 EDT 2025
Powered by FUDForum. Page generated in 0.04285 seconds
