Home » Archived » Visual Editor (VE) » Problems on opening VisualClass with VE
Problems on opening VisualClass with VE [message #17789] Tue, 03 February 2004 07:29 Go to next message
while trying to open a Visual Class with the VE, this error occures:
java.lang.VerifyError: (class:
org/eclipse/ve/internal/java/codegen/editorpart/JavaVisualEd itorPart,
method: createPaletteViewer signature:
(Lorg/eclipse/swt/widgets/Composite;)V) Incompatible object argument for
function call
at java.lang.Class.newInstance0(Native Method)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:151)
at org.eclipse.ui.internal.EditorManager$3.run(EditorManager.ja va:676)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:674)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:661)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:459)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:431)
... (cut here, full stack trace on request)
My environment (on Win2000):
Eclipse 2.1.2 (build 200311030802)
EMF 1.1.1 (20031120_1149WL)
GEF SDK 2.1.2 (I20031015)
VE 0.5.0
Is there something wrong within this configuration?
Björn
Re: Problems on opening VisualClass with VE [message #17795 is a reply to message #17789] Tue, 03 February 2004 09:35 Go to previous message
Originally posted by: mendelgili.netscape.net
Björn Droste wrote:
> Hello,
> function call
> at
> at
> at
> at
> at
> at
> at
> at
> at
> VE 0.5.0
> Best regards,
> Björn
The levels looks ok.
Have you tried to install this all from scratch?
Re: Problems on opening VisualClass with VE [message #580103 is a reply to message #17789] Tue, 03 February 2004 09:35 Go to previous message
Björn Droste wrote:
> Hello,
> function call
> at
> at
> at
> at
> at
> at
> at
> at
> at
> VE 0.5.0
> Best regards,
> Björn
Previous Topic:Problems on opening VisualClass with VE
Next Topic:Problems with classes that extends from JFrame in VE.
Current Time: Sun Jul 13 19:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.03297 seconds
