Home » Language IDEs » C / C++ IDE (CDT) » indexer bugs?
indexer bugs? [message #187139] Tue, 06 March 2007 08:53
Originally posted by: wadimd.gmail.com.usun.to
hello,
1.
I've played recently with CDT4 nightlies and found that the indexer
cannot find files for includes of form #include <somedir/blah.h> even if
project include path is set to proper directory where somedir/blah.h can
be found.
Log message is: "Preprocessor Inclusion not found:
isserverplus/util/logging/revision_id.h in file: C:\dev\src\is-server-
plus\isserverplus.datasupply.flashware\source\CaesarVersionN umber.cpp
on line: 4."
Hovewer, when <> are changed to "" then suddenly indexer catches the
source and displays suggestions/jumps to definitions.
This can be regularly observed e.g. on 20070219 build. On latest nightly
the includes are not always found after adding include path in project
properties and changing <> to "". For some cases it works for some not.
btw: What are the rules of indexer using the project include path settings?
2.
The workspace log file shows null pointer exceptions from indexer/parser
of form:
org.eclipse.cdt.internal.core.index.composite.cpp.CPPComposi tesFactory.getCompositeScope(CPPCompositesFactory.java:73)
org.eclipse.cdt.internal.core.index.composite.CompositeScope .getParent(CompositeScope.java:42)
I tried to find any regularity in occuring this problem but I failed. I
can only say that happened when I had more than one project in workspace
and indexer was gathering information.
(Actually our workspace is quite big, with circa 40 c++ projects for
various modules)
Are these problems known to You or should I submit bugs?
regards,
Wadim Dziedzic
Previous Topic:Build my own project template.
Next Topic:Console - interaction with user.
Current Time: Fri Jul 18 18:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.02817 seconds
