Home » Eclipse Projects » JFace » [databinding] ObservableListTreeContentProvider with IObservableList in different realm
[databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #17709] Tue, 30 June 2009 18:00 Go to next message
ObservableListTreeContentProvider documentation is clear that its
IObservableFactory must create lists on the realm of the current display.
In my case, I have an IObservableList for the root of the tree that is not
necessarily on the display realm. Is there a simple way to proxy from one
realm to another?
I guess I could create a new WritableList on the display realm and bind the
two together with a DataBindingContext. In this case, however, I just need
updates to propagate one way - from the source model list to the display
realm proxy.
-Will
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #18545 is a reply to message #17709] Wed, 01 July 2009 12:19 Go to previous messageGo to next message
I would use a binding for this as you mentioned.
Matthew
> display. In my case, I have an IObservableList for the root of the tree
> that is not necessarily on the display realm. Is there a simple way to
> proxy from one realm to another?
> the two together with a DataBindingContext. In this case, however, I
> just need updates to propagate one way - from the source model list to
> the display realm proxy.
> -Will
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #19324 is a reply to message #18545] Tue, 07 July 2009 20:57 Go to previous messageGo to next message
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:h2g2av$i55$1@build.eclipse.org...
How about this:
public class ProxyList extends WritableList {
public static IObservableList create(IObservableList original) {
return create(Realm.getDefault(), original);
public static IObservableList create(Realm realm, IObservableList
original) {
if (realm.equals(original.getRealm())) {
return original;
ProxyList list = new ProxyList(realm, original);
list.init();
return list;
private final DataBindingContext mDataBindingContext;
private IObservableList mOriginal;
private ProxyList(Realm realm, IObservableList original) {
super(new ArrayList<Object>(), original.getElementType());
mOriginal = original;
mDataBindingContext = new DataBindingContext();
private void init() {
mDataBindingContext.bindList(this, mOriginal);
public synchronized void dispose() {
mDataBindingContext.dispose();
super.dispose();
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #19507 is a reply to message #19324] Wed, 08 July 2009 14:41 Go to previous messageGo to next message
You will get an NPE in ProxyList.create(IObservableList) if
Realm.getDefault() == null. Other than that it looks good.
Another option is to just create a WritableList and add a dispose
listener that disposes the binding context, rather than subclassing:
public static IObservableList create(Realm realm, IObservableList list) {
if (realm.equals(original.getRealm())) return list;
IObservableList proxy = new WritableList(realm);
final DataBindingContext bindingContext = new DataBindingContext();
bindingContext.bindList(proxy, original);
proxy.addDisposeListener(new IDisposeListener() {
public void handleDispose(DisposeEvent) {
bindingContext.dispose();
return proxy;
Matthew
> How about this:
> original) {
> return original;
> list.init();
> return list;
> @Override
> super.dispose();
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #20510 is a reply to message #19507] Sun, 12 July 2009 19:54 Go to previous messageGo to next message
Thanks for the tips. One more question: is it necessary/good to dispose the
WritableList too?, e.g.
public static IObservableList proxyList(Realm realm, IObservableList
original) {
if (original.getRealm().equals(realm)) {
return original;
final WritableList list = new WritableList(realm);
final DataBindingContext dbc = new DataBindingContext();
original.addDisposeListener(new IDisposeListener() {
public void handleDispose(DisposeEvent staleEvent) {
list.dispose();
dbc.dispose();
dbc.bindList(list, original);
return list;
news:h32p8q$rp$1@build.eclipse.org...
> Another option is to just create a WritableList and add a dispose listener
> return proxy;
> Matthew
>> How about this:
>> original) {
>> return original;
>> list.init();
>> return list;
>> @Override
>> super.dispose();
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #20544 is a reply to message #20510] Mon, 13 July 2009 12:09 Go to previous messageGo to next message
> the WritableList too?
Yes, it is considered best practice.
Matthew
Re: [databinding] ObservableListTreeContentProvider with IObservableList in different realm [message #20632 is a reply to message #20544] Tue, 14 July 2009 15:17 Go to previous message
For future readers of this thread, here is the code I have ended up with.
Similar stuff should work for ObservableValue.
* Returns an observable list that proxies on the current realm for the
list
* passed in. The original list will be returned if its realm is the
current
* realm.
* @param original
* the list to proxy
* @return the proxy list
* @throws IllegalArgumentException
* if original is null
* @throws IllegalStateException
* if this thread has no default realm
* if the default realm is not the current realm
public static IObservableList proxyList(IObservableList original) {
Realm realm = Realm.getDefault();
if (realm == null) {
throw new IllegalStateException(
"this method requires a default realm"); //$NON-NLS-1$
return proxyList(realm, original);
* Returns an observable list that proxies on the given realm for the
list
alread
* the provided realm.
* @param original
* the list to proxy
* if realm is null
* if the provided realm is not the current realm
throw new IllegalArgumentException("the realm cannot be null");
//$NON-NLS-1$
if (original == null) {
throw new IllegalArgumentException("the original list cannot be
null"); //$NON-NLS-1$
if (!realm.isCurrent()) {
"must be called from the proxy realm"); //$NON-NLS-1$
return original;
final WritableList list = new WritableList(realm,
final DataBindingContext dbc = new DataBindingContext(realm);
list.dispose();
dbc.dispose();
return list;
Previous Topic:TreeViewer find node
Next Topic:[DataBinding] master-detail binding with non-String properties
Current Time: Tue Jul 08 03:52:40 EDT 2025
Powered by FUDForum. Page generated in 0.56527 seconds
