Home » Archived » M2M (model-to-model transformation) » [ATL] superimposition question
[ATL] superimposition question [message #17692] |
Thu, 22 February 2007 07:39  |
Originally posted by: markus.herrmannsdoerfer.bmw-carit.de
I read in the corresponding bug report that it is now possible to use a
feature called superimposition. Is a superimposed module aware of the
module it is superimposing? Or more concretely, is it possible to access
rules of the root module from a superimposed module? How can this be done?
Thanks in advance.
Markus
Re: [ATL] superimposition question [message #17745 is a reply to message #17692] |
Thu, 22 February 2007 12:35   |
Markus Herrmannsdoerfer schreef:
Hi Markus,
> Thanks in advance.
> Markus
Modules are not at all aware of any superimposition going on.
Superimposition is done at load-time. Access includes invocation of
called rules and helper methods, as well as helper attributes. I have
not tested rule inheritance yet, so I don't know what will happen ;-).
You can actually access any module in the same run, whether it is
superimposing or superimposed upon. It is of course bad practice to
introduce references from the root module to any of the superimposed
modules, so you'll probably want to reference downward only.
The safest (and original) use of superimposition is to mask matched
rules from the root module. Any matched rule in a superimposed module
with the same _name_ as a matched rule in the root module will replace
it (it masks the old rule).
Coming back to your previous post: you can use the rule masking feature
to redefine rules of the root copying transformation. You cannot reuse
parts of a masked out rule, however. Hence, masking rules is only
interesting when redefining relatively few rules.
Kind regards,
Dennis Wagelaar
Re: [ATL] superimposition question [message #18495 is a reply to message #17745] |
Fri, 23 February 2007 08:48   |
thanks for your answers. I have some more questions ;-) (see below)
> Hi Markus,
>> a feature called superimposition. Is a superimposed module aware of
>> the module it is superimposing? Or more concretely, is it possible to
>> access rules of the root module from a superimposed module? How can
>> this be done?
>> Thanks in advance.
>> Markus
Do I have to use the "uses" statement in order to be able to access a
rule from another module?
Assume I have the following rules in the root module:
rule A {
rule B extends A {
1. Is it possible to mask B in another module and still extending A from
the root module?
2. If I mask A in another module, will B in the root module then extend
the new A?
> Kind regards,
> Dennis Wagelaar
Kind regards,
Markus Herrmannsdörfer
Re: [ATL] superimposition question [message #18503 is a reply to message #17745] |
Fri, 23 February 2007 08:54   |
> Hi Markus,
>> this be done?
>> Thanks in advance.
>> Markus
rule A {
rule B extends A {
the root module?
the new A?
> Kind regards,
> Dennis Wagelaar
Kind regards,
Re: [ATL] superimposition question [message #19420 is a reply to message #18503] |
Wed, 28 February 2007 03:50  |
Hi Markus,
I'll try to answer them ;-).
>>> Hi,
>> Hi Markus,
>>> this be done?
>>> Thanks in advance.
>>> Markus
No, this is not strictly necessary. Then again, I believe it is also not
necessary when accessing library helpers. Currently, the "uses"
statement does nothing as far as I know...
On the other hand, it doesn't hurt to add a "uses" statement. It adds
more clarity and may even become a future requirement ;-).
I've tried it out for my transformations: commenting in and out a "uses"
statement makes no difference in the .asm file.
>> feature to redefine rules of the root copying transformation. You
>> cannot reuse parts of a masked out rule, however. Hence, masking rules
>> is only interesting when redefining relatively few rules.
> rule A {
> rule B extends A {
> the root module?
No, this is not possible. The "extends" statement is a compile-time
construction. At compile-time (i.e. .atl to .asm), only single modules
are considered. Superimposition is a load-time costruction, that links
the .asm files just before running them.
A possible solution here is to make "A" a called rule, which is then
called from matched rule "B". In a superimposing module, it is then
possible to mask "B" with a new rule that still calls rule "A".
> the new A?
No, the "extends" statement is compiled in such a way that rule "A" is
simply in-lined in rule "B". No relationship between "A" and "B" exists
in the .asm file.
Again, if "A" were a called rule, it would be masked by any newly
defined called rule "A". Rule "B" then indeed invokes the new rule "A".
>> Kind regards,
>> Dennis Wagelaar
> Kind regards,
Current Time: Thu Aug 28 14:43:44 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
