Why is the JDK source "Unknown Source"? [message #186858] |
Thu, 04 January 2007 22:41 |
Originally posted by: qu0llSixFour.gmail.com
Whenever my application throws an exception that occurs inside the JDK
source code, the source is not available (it says "Unknown Source") so I am
unable to determine the line number or browse the source. Why is this and
how do I fix it? If I go into Preferences JRE_SRC is pointing to the
src.zip in the correct location. I am using Eclipse 3.3M1 and Java 6.0
FCS. What else should I be looking at? Exceptions thrown from my own
source are not affected by this problem.
And loving it,
qu0ll
______________________________________________
qu0llSixFour@gmail.com
(Replace the "SixFour" with numbers to email)
Re: Why is the JDK source "Unknown Source"? [message #186914 is a reply to message #186858] |
Thu, 04 January 2007 08:56 |
are you sure that you are using JDK 6.0?
try this :
Window->Preferences->Java->Installed JREs
make sure that checked (default) configuration's JRE home directory
points to installed JDK
bartosz michalik
Re: Why is the JDK source "Unknown Source"? [message #187137 is a reply to message #186914] |
Sat, 06 January 2007 08:41 |
"Bartosz Michalik" <nugaee@SPAMtlen.pl> wrote in message
news:enl3se$87i$1@utils.eclipse.org...
> qu0ll napisal(a):
>> am
>> and
> try this :
> make sure that checked (default) configuration's JRE home directory points
> to installed JDK
Yep, it's definitely pointing to the right directory. What else could be
causing this?
And loving it,
qu0ll
Re: Why is the JDK source "Unknown Source"? [message #187169 is a reply to message #187137] |
Sat, 06 January 2007 20:16 |
>> qu0ll napisal(a):
>>> am
>>> and
>> try this :
>> to installed JDK
> causing this?
Are you refering to exceptions displayed in the stack trace? If so, it
is an indication that the java libraries you are running against aren't
compiled with debugging information. I don't think that Sun releases
the java libraries compiled with debugging information.
Re: Why is the JDK source "Unknown Source"? [message #187255 is a reply to message #187137] |
Sun, 07 January 2007 07:26 |
>> try this :
>> to installed JDK
> causing this?
can you send me content of org.eclipse.jdt.core.prefs from <workspace
dir>\.metadata\.plugins\org.eclipse.core.runtime\.settings ??
FUDForum. Page generated in 0.08420 seconds
