1"Document" with many reports [message #186290] |
Mon, 21 August 2006 04:23 |
Originally posted by: dm.sobacosoftware.com
Hello to everyone,
my problem is the follow;
I need create an "Asset statements", and this one is composed by many
different reports. The data source is an only XML file, relative to one
customer, with, for example, 5/6 or more sub-sets of data.
The question is:
It is possible create one single Report/Document, composed, for example,
by 5/6 or more reports relative to the same XML and obtain at the end one
big report(pdf file in my case) with index and all the reports as part of
the same documents.
It is possible with Birt to do that ? If yes which is the correct
structure to give at my documents? Which is the correct way to obtain that?
Thanks a lot!!!!!!
FUDForum. Page generated in 0.03524 seconds
