Home » Eclipse Projects » Eclipse Platform » problems with .registry
problems with .registry [message #185886] Wed, 28 January 2004 06:46 Go to next message
Originally posted by: chlai88.yahoo.com
hi,
there seems to be a problem with uninstalling plugins on the 3.0 m6 build. i
installed a plugin and then i uninstall the plugin by deleting the
corresponding directories from the features and plugins dir. but then i have
a problem restarting. it seems the .registry file is corrupted somehow. i
manage to restart by deleting the .registry file but all the workspace info
is now gone. is there a utility to edit the .registry file in cases like
this. here is the stack trace in .log :
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Jan 28, 2004 03:37:20.913
!MESSAGE Exception launching the Eclipse Platform:
!STACK
org.eclipse.ui.internal.registry.RegistryReader$1.compare(Re gistryReader.jav
a:103)
at java.util.Arrays.mergeSort(Arrays.java:1278)
at java.util.Arrays.sort(Arrays.java:1219)
at java.util.Collections.sort(Collections.java:155)
at org.eclipse.ui.internal.registry.RegistryReader.orderExtensi onshe
..registry (RegistryReader.java:107)
org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.
java:158)
org.eclipse.ui.internal.registry.WizardsRegistryReader.readW izards(WizardsRe
gistryReader.java:156)
org.eclipse.ui.internal.registry.NewWizardsRegistryReader.re adWizards(NewWiz
ardsRegistryReader.java:350)
org.eclipse.ui.internal.registry.NewWizardsRegistryReader.ge tWizardElements(
NewWizardsRegistryReader.java:371)
at org.eclipse.ui.actions.NewWizardMenu.hasExamples(NewWizardMe nu.java:212)
at org.eclipse.ui.actions.NewWizardMenu.fillMenu(NewWizardMenu. java:119)
at org.eclipse.ui.actions.NewWizardMenu.fill(NewWizardMenu.java :196)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :573)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :462)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 10)
at org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:147)
org.eclipse.jface.window.ApplicationWindow.configureShell(Ap plicationWindow.
java:294)
org.eclipse.ui.internal.WorkbenchWindow.configureShell(Workb enchWindow.java:
714)
at org.eclipse.jface.window.Window.createShell(Window.java:353)
at org.eclipse.jface.window.Window.create(Window.java:304)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1136)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:875)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1459)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Chern-Horng Lai
Re: problems with .registry [message #192353 is a reply to message #185886] Tue, 10 February 2004 23:13 Go to previous message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
yup. known problem in M6. Should be fixed now.
"hanzi" <chlai88@yahoo.com> wrote in message
news:bv87bs$v6q$1@eclipse.org...
> hi,
i
have
info
> !STACK
> java.lang.NullPointerException
> at
> a:103)
> at
> java:158)
> at
> at
> at
> at
> at
> at
> java:294)
> at
> 714)
> at
> at
> at
> java:226)
> at
> at
> at
> .java:25)
> Chern-Horng Lai
Previous Topic:How to Move Eclipse Directory Safely
Next Topic:When is a plugin a dependency of another?
Current Time: Thu Nov 06 15:05:09 EST 2025
Powered by FUDForum. Page generated in 0.02968 seconds
