Home » Eclipse Projects » GEF » xml editor
xml editor [message #17542] Wed, 21 August 2002 09:10 Go to next message
Originally posted by: bkandan.selectica.com
hi,
i am trying to create an xml editor using gef...whenever a new node is
added, i need to connect the previously selected node and the newly created
node programatically...
wat shud i do?
Thanks in advance...
Balaji
Re: xml editor [message #17568 is a reply to message #17542] Wed, 21 August 2002 09:38 Go to previous messageGo to next message
Originally posted by: hudsonr.spam.com
Is this connection really in your model, or you just need to see a line
between the nodes?
"netbeans" <bkandan@selectica.com> wrote in message
news:ak02vs$4d8$1@rogue.oti.com...
> hi,
created
> wat shud i do?
> Balaji
Re: xml editor [message #17581 is a reply to message #17568] Wed, 21 August 2002 10:45 Go to previous messageGo to next message
i just need to see the connection...and is not included in the model...
Balaji
"Randy Hudson" <hudsonr@spam.com> wrote in message
news:ak04ke$5a6$1@rogue.oti.com...
> between the nodes?
> > hi,
> created
> > wat shud i do?
> > Balaji
Re: xml editor [message #17593 is a reply to message #17581] Wed, 21 August 2002 10:55 Go to previous messageGo to next message
So, you could do this lots of ways. You don't need a connection EditPart,
maybe just a PolylineConnection. Such a connectoin could be added by the
editpart, or even by some custom figure that the editpart uses. But, it
could be even simpler than this. If you know exactly where the line will
be, for example you are doing something like a Tree, You could just draw a
line down the left side of the Figure, or even use a Border which paints the
line. I'd have to see a mockup to offer more advice.
news:ak08gj$7qf$1@rogue.oti.com...
> Balaji
> > between the nodes?
> > > hi,
is
> > created
> > > wat shud i do?
> > > Balaji
Re: xml editor [message #17607 is a reply to message #17593] Wed, 21 August 2002 11:23 Go to previous messageGo to next message
but for creating a connection, we need source and target node...where will
get the nodes from??
and i have one more problem i am able to increase the size of the nodes
using the resize handle, but i am not able to reduce the size of the
nodes...can u tell me where i am going wrong?
sorry if it seems like a silly question...but just now i have started
learning gef...
news:ak096e$8cp$1@rogue.oti.com...
the
> > Balaji
line
> > > between the nodes?
> > > > hi,
node
> is
> > > created
> > > > wat shud i do?
> > > > Balaji
Re: xml editor [message #17619 is a reply to message #17607] Wed, 21 August 2002 11:39 Go to previous messageGo to next message
Not for a draw2d connection. You just need a line with two
ConnecitonAnchors. Don't worry about GEF connectoins unless you need
something that is selectable, and the user can delete, bend, reocnnect, etc.
This is fixed in the latest code. A new ZIP will be available soon, or you
can pull the source from the CVS repository.
As a workaround, you can do:
node.setMinimumSize(new Dimension(10,10));
> learning gef...
Re: xml editor [message #17632 is a reply to message #17619] Wed, 21 August 2002 11:53 Go to previous messageGo to next message
thanks for the reply...
but will it behave like polylineconnection when the user moves the node...
and for that resize matter...the one in the logic example is working
fine...i'll see to that...
news:ak0bo4$agq$1@rogue.oti.com...
will
etc.
you
> > learning gef...
Re: xml editor [message #17644 is a reply to message #17632] Wed, 21 August 2002 13:28 Go to previous messageGo to next message
news:ak0cgf$avn$1@rogue.oti.com...
Logic example is not the general case. It works there I believe because the
"nodes" have a ScrollPane in them, and ScrollPane implements
getMinimumSize() in a meaningful way. General figures don't have a minimium
size, so they return their current size.
Re: xml editor [message #17695 is a reply to message #17644] Thu, 22 August 2002 05:14 Go to previous messageGo to next message
hi Randy,
abt the line and the connection anchor in ur previous reply, can u
explain me how todo that?
'cos when the new node gets created i have to connect the previously
selected node and the newly created node...where shud i write the code for
connecting these nodes?
Thanks in advance
Balaji.
news:ak0i4b$e55$1@rogue.oti.com...
node...
the
minimium
Re: xml editor [message #17708 is a reply to message #17695] Thu, 22 August 2002 06:50 Go to previous message
hi man,
i found out how to do this by myself...
thanks for the clue....
Balaji
news:ak29f9$8f6$1@rogue.oti.com...
> hi Randy,
> Thanks in advance
> Balaji.
> node...
> the
> minimium
Previous Topic:Animation with GEF
Next Topic:can the model hierarchy be different from the editpart hierarchy
Current Time: Sun Jul 13 15:42:40 EDT 2025
Powered by FUDForum. Page generated in 0.04333 seconds
