Home » Language IDEs » ServerTools (WTP) » Extend/use editor in custom plugin (XMLMultiPageEditorPart)
Extend/use editor in custom plugin (XMLMultiPageEditorPart) [message #185561] Thu, 04 January 2007 14:05 Go to next message
Originally posted by: durchgedreht.gmx.de
FIRST OF ALL:
I know this is WTP internal and may not be future compliant. Anybody
reading this should be aware of this (if an extension point will help me,
any idea is also welcome).
I want to use the XML editor of the WTP package. The problem I have: I use
an own file extension. That file extension has a MultiPartEditor attached
as I want to deliver a GUI based editor for the user. As I use XML I also
want to have a tab in the MultiPageEditor to allow XML Source Code
modification. How can I Use the existiong editor
" org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part " ???
Aim:
1. Page: My visual editor
2. Page: eclipse wtp XML visual editor
3. Page: eclipse wtp XML source editor
I got it running with an own editor definition and class. My class
inherits from XMLMultiPageEditor and therefore has the Functionality I
want. But this should not be done as it throws a warning (Discuraged
Access due to restriction). So how do I solve this without workarounds?
THX!
Dennis
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
Re: Extend/use editor in custom plugin (XMLMultiPageEditorPart) [message #185581 is a reply to message #185561] Thu, 04 January 2007 14:35 Go to previous messageGo to next message
Originally posted by: b.muskalla.gmx.net
Hi Dennis,
this could help you:
http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipage-editor-tutorial.html
Greets
Benny
Dennis Meyer wrote:
> FIRST OF ALL:
> me, any idea is also welcome).
> Aim:
> THX!
> Dennis
> --Erstellt mit Operas revolutionärem E-Mail-Modul:
Re: Extend/use editor in custom plugin (XMLMultiPageEditorPart) [message #185623 is a reply to message #185581] Fri, 05 January 2007 04:18 Go to previous messageGo to next message
Thanks, this was EXACTLY what I was looking for!
Anyway, I have troubles in getting the "right" XML editor. When I ollow
the tutorial step by step, ll works fine. But when I test the plugin and
open a XML file, the text will not be highlighted and no CTRL-Space help
is active. When I right click the editor pane and choose preferences, I
will get the TextEditor.
When right-clicking the XML file I can choose the different editors
(MyTutorialEditor and XMLEditor) and the XML Editor will show the WTP XML
Editor with all features enabled, so it is installed. Any ideas what went
wrong?
Dennis
Am 04.01.2007, 20:35 Uhr, schrieb Benjamin Muskalla <b.muskalla@gmx.net>:
> Hi Dennis,
> Greets
> Benny
> Dennis Meyer wrote:
>> FIRST OF ALL:
>> I use
>> attached
>> also
>> Aim:
>> THX!
>> Dennis
Re: Extend/use editor in custom plugin (XMLMultiPageEditorPart) - SOLVED [message #185639 is a reply to message #185623] Fri, 05 January 2007 05:55 Go to previous message
it seems like I've been sleeping while reading <SHAME on me!>
I simply forgot to change TextEditor to StructuredTextEditor.
Tanks a lot for your help!
Dennis
Am 05.01.2007, 10:18 Uhr, schrieb Dennis Meyer <durchgedreht@gmx.de>:
> ollow the tutorial step by step, ll works fine. But when I test the
> plugin and open a XML file, the text will not be highlighted and no
> CTRL-Space help is active. When I right click the editor pane and choose
> preferences, I will get the TextEditor.
> XML Editor with all features enabled, so it is installed. Any ideas what
> went wrong?
> Dennis
>> Hi Dennis,
>> Greets
>> Benny
>> Dennis Meyer wrote:
>>> FIRST OF ALL:
>>> Hi,
>>> I use
>>> attached
>>> also
>>> Aim:
>>> workarounds?
>>> THX!
>>> Dennis
Previous Topic:Debug Code
Next Topic:XML File Validation Using NameSpace
Current Time: Sun Aug 31 06:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.03496 seconds
