Home » Language IDEs » ServerTools (WTP) » Obtaining source for org.eclipse.wst. * during debugging
Obtaining source for org.eclipse.wst. * during debugging [message #185511] |
Tue, 02 January 2007 19:00  |
Originally posted by: fakeaddress.brainkandy.org
I've done some reading, but cannot find much in the way of helpful
information.
The problem:
When trying to view the source of any class in org.eclipse.wst.* (though
specifically the four packages listed at [1], I am met with the message
"The JAR of this classfile belongs to the container 'Plug-in
Dependencies'. To configure the source attachment, go directly to the
corresponding configuration page (For example for JREs go to 'Installed
JREs' page in preferences.)
Now, I have a copy of the WST source code in $HOME/workspaces/wst/wst
and attempted to register those source locations at this location;
Preferences Menu/Plug-in Development/Target Platform/Source Code
Locations Tab
Additional source locations:
$HOME/workspaces/wst/wst/components/xml/plugins/org.eclipse. wst.xml.ui/src,
and so on.
Unfortunately, Eclipse still can't locate the source for (for instance)
org.elilpse.wst.xml.ui.internal.contentassist.NoRegionConten tAssistProcessor.
Now, I've been reading online documentation, printed documentation and
web documentation, and I'm just still stuck, and could use a little
help. Thanks!
Robert Konigsberg
[1]: org.eclipse.wst.sse.ui, org.eclipse.wst.xml.ui,
org.eclipse.wst.sse.core, org.eclipse.wsst.xml.core
Re: Obtaining source for org.eclipse.wst. * during debugging [message #185708 is a reply to message #185511] |
Fri, 05 January 2007 23:50   |
On Tue, 02 Jan 2007 19:00:31 -0500, Robert Konigsberg <fakeaddress@brainkandy.org> wrote:
> Locations Tab
> and so on.
I haven't used this feature is a year or more, but my (faint) memory of it
is that the PDE source code location tab is to be used (by PDE) when you say,
for example, to "import project as source" (from your target).
Do you have a target defined? If not, you might be able to preserve your existing
install by creating a target, consisting of the SDK versions, as Konstantive suggested.
I believe your target has to be a "complete" Eclipse install, meaning you'd need at
least the platform, plus WTP, etc.
Then, when you run "debug", it basically uses the plugins from your target (plus ones
in your dev. env. that are not be in your target). Then, once you've seen what you
needed, if desired, you can always just stop using the target ... depending on
what your needs. And, if you just wanted to browse the source code, I think the
easiest way, once you have your target defined, is to "import plugin as source".
If you just wanted to add it to Java Search, there's an option for that too :)
Unfortunately, I'm not familar with just having "loose source" from CVS associated with
jars in Eclipse ... that may not be possible as Eclipse depends
pretty strongly on it's own project model.
Re: Obtaining source for org.eclipse.wst. * during debugging [message #185950 is a reply to message #185708] |
Wed, 10 January 2007 23:02   |
>> Locations Tab
>> and so on.
Hey everyone, thanks for your help. You know what? I went with
Konstantin's first recommendation and downloaded a complete install.
That really helped, wow did that help.
Thanks!
Re: Obtaining source for org.eclipse.wst. * during debugging [message #186919 is a reply to message #185950] |
Wed, 24 January 2007 20:03   |
Hello again,
Something strange happened with my environment, and I can't tell what I did:
For weeks, I have been successfully able to browse the source of any
plugin that is a dependency of my own plugin.
Somehow, all that has changed: now whenever I attempt to open, for
example, org.eclipse.wst.sse.ui.StructuredTextViewerConfiguration, I get
"Source not found" where I used to get the source.
To continue with the example, the plugin "org.eclipse.wst.sse.ui" is
included in my project as a required plugin. There are no additional
properties related to the pugin (it's not optional, nor is reexport
enabled.)
Please advise. Is it possible I did something wicked with my
environment? Thanks!
>>> Locations Tab
>>> and so on.
>> of it
>> you say,
>> your existing
>> you'd need at
>> target (plus ones
>> seen what you
>> depending on
>> think the
>> as source".
>> that too :)
>> CVS associated with
> Thanks!
Re: Obtaining source for org.eclipse.wst. * during debugging [message #186935 is a reply to message #186919] |
Wed, 24 January 2007 22:21  |
Again, Hello Again.
I figured it out. Pretty interesting actually.
Preferences menu, select Plug-in Development, and from there the Target
Platform tab.
Now, I have two installations of Eclipse on my machine, and both are
listed as "locations", *and* the, er, wrong one, was selected. Selecting
the 'right one' and clicking 'Reset' did the trick.
Whew.
> Hello again,
> did:
> enabled.)
>>>> Locations Tab
>>>> and so on.
>>> of it
>>> you say,
>>> your existing
>>> you'd need at
>>> target (plus ones
>>> seen what you
>>> depending on
>>> think the
>>> as source".
>>> that too :)
>>> CVS associated with
>> Thanks!
Current Time: Sun Jun 08 01:43:10 EDT 2025
Powered by FUDForum. Page generated in 0.23982 seconds
