Profiling weblogic using TPTP [message #185371] |
Thu, 21 December 2006 13:28 |
Originally posted by: cidoni.gmail.com
I am trying to profile my web application running in weblogic 8.1 using
eclipse TPTP. Below is the installation info.
Eclipse WTP 1.5.2, TPTP 4.3.0, JRE 1.4.2_10 (Same JRE used for eclipse,
tptp and Weblogic)
OS: Win XP
I got to know that eclipse TPTP does not support profile on server feature
for weblogic 8.1 server (Ref:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=126594)
I am trying the approach mentioned in the above bug description.
ie, I start weblogic 8.1 server within eclipse with the VM argument
-XrunpiAgent in the server's launch configuration. I have enabled the
Integrated Agent Controller in Eclipse and checked "Always running",
"Enable logging" and "Allow remote connections". Remote connection port is
set to 10002.
I had the old Agent Controller running before, but I have removed it now.
Its no more in the system PATH as well.
Now, the problem is, when I try to profile and create a new configuration
using "Attach - Java Process", it is not listing any agents. An error
message "IWAT0225E You must select at least one agent to attach to." is
shown on top.
The "Hosts" tab has Local Direct Connection and localhost:10002. Test
connection on Local Direct Connection shows successful. But on
localhost:10002 shows "A Local Direct Connection is currently active.
Before starting the Remote Agent Controller(RAC) you need to detach all
agents running using this Local Direct Connection".
I am stuck with this for couple of days now. Any help on this will be
highly appreciated.
Thanks in advance,
Cidoni
FUDForum. Page generated in 0.08119 seconds
