two graphic elements associated to the same ecore element [message #185107] |
Sat, 03 May 2008 06:44 |
Originally posted by: bmoros.um.es
Hi all,
I would like to know if it is possible to associated two different graphic
elements (a link and a node) to the same concept in the ecore diagram. The
ecore concept is called "Trace". When creating a Trace, I know the source
element and I would like to create a new link connecting this source to a
new node which contains some Trace information. So I have to create both the
link and a node. The node just will show some Trace attributes. One of the
trace attributes will be an EObject from other resource.
Someone knows whether it is possible or not
Thanks in advance.
Bego
FUDForum. Page generated in 0.26948 seconds
