Home » Newcomers » Newcomers » Error while export of RCP application
Error while export of RCP application [message #184821] Mon, 18 December 2006 07:07 Go to next message
Originally posted by: rajan.ranjeev.de.bosch.com
I have an RCP Application. I have made a Product Configuration with 3
plugins and it's dependent plugin added in the configuration. Now when I
invoke my "Eclipse Product Export Wizard", I get an error Message Dialog,
Reason:
D:\xyz\.metadata\.plugins\org.eclipse.core\temp\org.eclipse. container.feature\assemble.org.eclipse.pde.container.feature .win32.win32.x86.xml:77:java.io.EOFException
I'm not able to figure out on how to fix this problem.
Any help on this greatly appreciated!
Many Thanks
Ranjeev
Re: Error while export of RCP application [message #184907 is a reply to message #184821] Tue, 19 December 2006 09:54 Go to previous message
Hello Friends,
I have found a solution for the problem and thought, I will share the
same. Actually I had my Plugins stored in M: drive (means in the network
drive) and I tried copying all the elements to my local drive and then I
export my RCP application again. And it worked without any problem.
Previous Topic:Find reference method not working
Next Topic:AccessControlException: access denied (java.io.FilePermission
Current Time: Sun Jun 29 22:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.07977 seconds
