Home » Eclipse Projects » Eclipse Platform » Pb with launching eclipse ...
Pb with launching eclipse ... [message #184508] Sun, 25 January 2004 03:06 Go to next message
Originally posted by: fb.idylic.com
I have some pb to launch eclipse with Java support at startup
I can't edit any Java files and can't also configure anything about Java
in the "Windows->Preferences" dialog box.
I try to execute eclipse with different arguments in the command line nut
no result !
(I am under windows 2000)
Thanks for your replies !
François
Re: Pb with launching eclipse ... [message #184592 is a reply to message #184508] Sun, 25 January 2004 12:41 Go to previous message
Sounds like you downloaded the Platform Runtime Binary instead of the full
SDK which includes the Java and Plug-in development environments.
HTH
Darins
"Fran
Previous Topic:plugin.xml vertical toolbar menu setup
Next Topic:Eclipse errors on startup on MacOSX ...
Current Time: Sat Jul 19 04:18:16 EDT 2025
Powered by FUDForum. Page generated in 0.02865 seconds
