Home » Eclipse Projects » Plugin Development Environment (PDE) » -debug and .options
-debug and .options [message #17382] Tue, 26 August 2008 10:16 Go to next message
Originally posted by: Jonathan.L.Hendrix.nasa.gov
I'm trying to see why my plug-in isn't loading. This is the current
content of my .options file
org.eclipse.core.runtime/debug=true
org.eclipse.core.runtime/loader/debug=true
org.eclipse.core.runtime/loader/debug/create=true
org.eclipse.core.runtime/loader/debug/activateplugin=true
org.eclipse.core.runtime/loader/debug/actions=true
org.eclipse.core.runtime/loader/debug/success=true
org.eclipse.core.runtime/loader/debug/failure=true
org.eclipse.core.runtime/loader/debug/filter/loader=*
org.eclipse.core.runtime/loader/debug/filter/class=*
org.eclipse.core.runtime/loader/debug/filter/resource=*
org.eclipse.core.runtime/loader/debug/filter/native=*
I don't get any messages after it says .options was loaded.
I'm using eclipse 3.4.
Any ideas?
Re: -debug and .options [message #17843 is a reply to message #17382] Tue, 26 August 2008 10:57 Go to previous messageGo to next message
Is there any chance, that you have no newlines between the options? At
least my mail client shows them this way? This can confuse the debug
framework.
> Any ideas?
Re: -debug and .options [message #17854 is a reply to message #17843] Tue, 26 August 2008 11:08 Go to previous messageGo to next message
I used a dump program to verify that the lines end with cr/nl
Re: -debug and .options [message #17878 is a reply to message #17854] Tue, 26 August 2008 11:18 Go to previous messageGo to next message
Does someone know where there is a list of possible debug 'variables' to
set to true?
Re: -debug and .options [message #17930 is a reply to message #17878] Wed, 27 August 2008 02:13 Go to previous message
Originally posted by: zx.code9.com
> set to true?
If you're using PDE and Eclipse Application launch configurations, there
should be a 'tracing tab' where this information can be enabled and set
via a UI.
~ Chris
Re: -debug and .options [message #577215 is a reply to message #17382] Tue, 26 August 2008 10:57 Go to previous message
framework.
> Any ideas?
Re: -debug and .options [message #577240 is a reply to message #17843] Tue, 26 August 2008 11:08 Go to previous message
Re: -debug and .options [message #577292 is a reply to message #17854] Tue, 26 August 2008 11:18 Go to previous message
set to true?
Re: -debug and .options [message #577393 is a reply to message #17878] Wed, 27 August 2008 02:13 Go to previous message
> set to true?
via a UI.
~ Chris
Previous Topic:question about resourcetraversal
Next Topic:contributing to PackageExplorer view
Current Time: Mon Jul 14 13:37:45 EDT 2025
Powered by FUDForum. Page generated in 0.05369 seconds
