Home » Language IDEs » AspectJ » Introduction to more than one class does not work for AJDT 1.1.1
Introduction to more than one class does not work for AJDT 1.1.1 [message #17378] Wed, 19 March 2003 05:42 Go to next message
The following code is legal AspectJ and compiles with standalone AspectJ
1.0 and up, but not in AJDT 1.1.1:
public aspect TestAspect {
public String (Person || Boss).getTest() {
return "Test";
The compiler states that the "Return type for the method is missing".
I also tried using the aspectjtools.jar located in the plugin directory
from the commandline, and it gives me the same errors:
D:\workspace\TestAspects2\src\com\lhsystems\test2\BoldPerson .java:29
Any clues?
Peter
Re: Introduction to more than one class does not work for AJDT 1.1.1 [message #17392 is a reply to message #17378] Wed, 19 March 2003 07:23 Go to previous message
maybe you might find it of interest that the code below doesn't compile
with the aspectj 1.1 prerelease either. Taking a closer look at the
aspectjtools.jar, things get clearer: the compiler used by aspectJ 1.1 is
the eclipse compiler...
Peter Friese wrote:
> return "Test";
Re: Introduction to more than one class does not work for AJDT 1.1.1 [message #564927 is a reply to message #17378] Wed, 19 March 2003 07:23 Go to previous message
Peter Friese wrote:
> return "Test";
Previous Topic:Introduction to more than one class does not work for AJDT 1.1.1
Next Topic:WSAD aspectj sdk 1.4
Current Time: Mon Jul 14 00:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
