Home » Modeling » OCL » OCL Constraints on ECore Model
Re: OCL Constraints on ECore Model [message #17380 is a reply to message #17340] |
Wed, 18 April 2007 11:23   |
Hi, Ian,
No, EMF does not provide OCL support in the default templates. There is,
however, support planned for generating constraints (much as in [1]) from
UML models:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105199
for those of us who do all of our modeling with UML, not Ecore :-)
EMF does support the embedding of Java code in annotations on constraint
EOperations (those having the (DiagnosticChain, EMap) signature); I'm not
sure of the details.
Christian
Ian Bull wrote:
> This may be just my lack of understanding, but can "simple" OCL
> constraints be specified as Annotations on Ecore Models. I have looked
> at [1] and there is lots of talk about templates, but it is possible to
> just add a constraint (as an EAnnotation) to that says "self.something >
> 0" for example, without worrying about templates (i.e. are there default
> templates for working with OCL)?
[1] http://www.eclipse.org/articles/article.php?file=Article-EMF -Codegen-with-OCL/index.html
> Cheers,
> ian
Re: OCL Constraints on ECore Model [message #18713 is a reply to message #18641] |
Wed, 18 April 2007 15:34   |
Hi, Antonio,
Yes, my update of that article (for OCL 1.1) fixes some problems with
inherited EOperations and EStructuralFeatures, as well as generally
producing cleaner code. This update has yet to be published, but is
available as an attachment on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143580
I think Ian was specifically looking for out-of-the-box OCL support, not
requiring custom templates.
Christian
Antonio Carrasco wrote:
> Ian,
> If I understand properly, you can add OCL constraints to an EMF model,
> following Christians example:
> http://www.eclipse.org/resources/resource.php?id=124
> There were a couple errors in the codegen of constraints in classes
> specializing other classes, but this may have been fixed already.
> Ill send you my template fixes to your personal address
> (not sure I can post a .zip here).
> Cheers!
> ACV
> "Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
> news:f05d5g$ier$1@build.eclipse.org...
>> Hi, Ian,
>> UML models:
>> Cheers,
>> Christian
>>> Cheers,
>>> ian
Re: OCL Constraints on ECore Model [message #18872 is a reply to message #18803] |
Thu, 19 April 2007 09:14   |
Hi, Antonio,
It's great to hear that you're having such success with those templates!
That's very encouraging. I'm keen to know what you think of the "new &
improved" version, if you want to try it out! I've learned a few things
about the EMF templates since the first edition ...
Christian
> Ok! being the key aspect I didnt the custom templates.
> IMO, given the minimal effort it takes to aply your article,
> and the outstanding results,
> I just use systematically your templates for EMF codegen,
> with a couple minimal additions and the inheritance fix.
> Thanks a lot,
> ACV
Re: OCL Constraints on ECore Model [message #18914 is a reply to message #18894] |
Thu, 19 April 2007 10:32   |
Hi, Antonio,
In case you thought I was referring to the UML2 codegen enhancement for OCL
support, I wasn't. I was just referring to an update of my article, still
dealing with EMF codegen for Ecore:
If and when you do get a chance to review it, I'd appreciate it if you could
comment on that bug to nudge Wayne to post the update to Eclipse Corner
Christian
> Encouraging! Thanks,
> but actually its is possible to do really interesting things with just EMF
> and your templates,
> such that Ive not been forced to jump into UML2 codegen - yet.
> Some of the ideas for uses of the expressions come from previous work at
> IBM (IAA, IBEE, IBL),
> and BOCA:
> http://www.omg.org/docs/ad/99-10-09.pdf
> Ill look at it, soon.
> Cheers,
> ACV
<snip>
Re: OCL Constraints on ECore Model [message #19046 is a reply to message #18914] |
Thu, 19 April 2007 16:38  |
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
Indeed!
ACV
news:f07ugo$cr2$1@build.eclipse.org...
> Hi, Antonio,
> OCL
> could
> Cheers,
> Christian
>> EMF
>> and your templates,
>> and BOCA:
>> Cheers,
>> ACV
> <snip>
Current Time: Sun Jul 13 07:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.65946 seconds
