Home » Archived » Maven Integration (M2E) » [tycho] Product Export
[tycho] Product Export [message #17339] Fri, 17 October 2008 22:24 Go to next message
I've successfully run the tutorial at
http://docs.codehaus.org/display/M2ECLIPSE/Tycho+Product+Exp ort
Now I am trying to export a feature based product. I created a feature
project including the HelloWorld plugin and the org.eclipse.rcp feature.
I've tried both with the .product file in HelloWorld and
HelloWorld.feature. In either case I get an exception.
http://jira.codehaus.org/browse/MNGECLIPSE-943 implies that this should
be possible, but I haven't quite figured out the recipe.
I also noticed something about an "eclipse-application" packaging at
http://docs.codehaus.org/display/M2ECLIPSE/Tycho+user+docs but couldn't
see how that fit in with the original tutorial.
Thanks in advance for any help! Let me know if this isn't the right
list for Tycho.
-Will
Re: [tycho] Product Export [message #17379 is a reply to message #17339] Sat, 18 October 2008 18:43 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Will,
Current DEV build does not support neither feature-based products nor
eclipse-application packaging type, so you need to wait for the next
build (tentatively, early next week) to try these features. I will also
try to update the tutorial to show use of eclipse-application packaging.
> list for Tycho.
> -Will
Re: [tycho] Product Export [message #19393 is a reply to message #17379] Tue, 11 November 2008 07:21 Go to previous messageGo to next message
I am trying it
http://docs.codehaus.org/display/M2ECLIPSE/Tycho+Product+Exp ort but i have
not result ~~
The executable is not generated
Re: [tycho] Product Export [message #19438 is a reply to message #19393] Tue, 11 November 2008 15:05 Go to previous message
Sylvain,
Unfortunately, this does not provide us with enough information to
diagnose the problem. Can you please re-run the build with debug log
enabled (-X parameter on cli) and either post build output here or
create new bugreport in JIRA [1] and attach the log there? Also, what
operating system you're using?
[1] http://jira.codehaus.org/browse/MNGECLIPSE
Igor
Sylvain MOUQUET wrote:
> Hi
> I am trying it
> have not result ~~
> Thanks
Previous Topic:Can't access org.apache.maven classes
Next Topic:Tycho build 0.3.0-DEV-1785
Current Time: Fri Jul 18 22:43:35 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
