Home » Newcomers » Newcomers » Cant start Eclipse
Cant start Eclipse [message #183811] Mon, 11 December 2006 10:12 Go to next message
Originally posted by: priyadar.gmail.com
I just installed Eclipse 3.2.1 and when I try to start it - I get the
following error ::
I checked the permissions on the directories - and they seem fine. I am
using Java 1.4.2 on Windows XP Prof.
Any help is appreciated
!SESSION 2006-12-11 10:01:44.656
eclipse.buildId=M20060921-0945
java.version=1.4.2_01
Framework arguments: -configuration=C\Temp
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 4 0 2006-12-11 10:01:45.296
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1010)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1037)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in file:/C:/eclipse/configuration/
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.java:85)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:113)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
!ENTRY org.eclipse.core.runtime 4 0 2006-12-11 10:01:45.312
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
!ENTRY org.eclipse.osgi 4 0 2006-12-11 10:01:45.328
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.update.configurator_3.2.1.v2009200 6.jar/
is not active.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/
was not resolved.
!ENTRY org.eclipse.osgi 4 0 2006-12-11 10:01:45.343
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:65)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2006-12-11 10:01:45.343
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-12-11 10:01:45.343
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2006-12-11 10:01:45.343
!MESSAGE Missing required bundle
org.eclipse.equinox.preferences_[3.2.0,4.0.0).
org.eclipse.core.contenttype_[3.2.0,4.0.0).
org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle
[3] was not resolved.
!MESSAGE Missing optionally required bundle
org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
Re: Cant start Eclipse [message #183875 is a reply to message #183811] Mon, 11 December 2006 20:37 Go to previous messageGo to next message
I doubt this would be the cause, but I guess it might be worth trying to
start it with a newer JVM. 1.4.2.01 is pretty old. 1.4.2.10 is one of
the reference platforms though [1]. So I guess try that or higher.
[1] - http://www.eclipse.org/eclipse/development/readme_eclipse_3. 2.1.html
Rem
Re: Cant start Eclipse [message #184258 is a reply to message #183875] Tue, 12 December 2006 11:24 Go to previous messageGo to next message
> Rem
No the more likely cause, given his stated use of Windows XP, is that he
let the Windows XP default unzipper incorrectly unzip his Eclipse. The
failure results he gave are very much like the scores of others we've
seen just like it in this newsgroup over and over.
And the suggested fix is also the same as in all those other
situations... use a "real" unzipper (WinZip or the like).
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Cant start Eclipse [message #184284 is a reply to message #184258] Tue, 12 December 2006 15:59 Go to previous message
>> Regards,
>> Rem
I used Winzip to unzip the eclipse dld file. It tried again now (just in
case I missed anything) and a still getting the same error.
I will upgrade the JVM and try
- P
Previous Topic:Tomcat 5.0x fails to start from Servers pane
Next Topic:Assigning different value to ComboCellEditor at runtime
Current Time: Sat Jul 26 09:23:03 EDT 2025
Powered by FUDForum. Page generated in 0.31569 seconds
