Home » Archived » XML Schema Definition (XSD) » XSD Editor in Eclipse?
XSD Editor in Eclipse? [message #17293] Thu, 10 April 2003 13:34 Go to next message
Originally posted by: dirk.schesmer.divos.de
Hi all,
when surfing and scanning the messages, I got the impression that the
EMF/XSD library contains an editor plugin for Eclipse ? Is this correct and
how can I get a good starting point to use it? I could replace XMLSpy,
then...
Dirk V. Schesmer
Re: XSD Editor in Eclipse? [message #17384 is a reply to message #17293] Thu, 10 April 2003 14:29 Go to previous messageGo to next message
Dirk,
There is a Sample XML Schema Editor that XSD provides; just right click and do
"Open with" to try it out. EMF also lets you generate a model from a .xsd and
then generate an editor to edit model instances (i.e., XML instances of the XML
Schema). There will be a tutorial for how to do this available with the next
code drop. For now you can follow the existing tutorials at
www.eclipse.org/emf and choose the "Import from XML Schema" option when you get
to that part of the wizard. Or wait till next week...
"Dirk V. Schesmer" wrote:
> Hi all,
> then...
> Dirk V. Schesmer
Re: XSD Editor in Eclipse? [message #21315 is a reply to message #17384] Wed, 07 May 2003 04:55 Go to previous messageGo to next message
Originally posted by: paechoi.earthlink.net
Ed,
I have some questions regarding on this subject and hope you folks do
not mind me continuing this thread.
What does that mean when you said "just right click and do ..." in your
previous post? Was that for the Eclipse/Editor?
Is XSD Schema Editor pluggable to other apps other than Eclipse/Editor
as well? Then, is there any doc and/or sample as a starting point? Thank
you.
Pae
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3E95B805.918F9DFA@ca.ibm.com...
> Dirk,
and do
and
the XML
next
you get
> > Hi all,
and
> > then...
> > Thanks,
> > Dirk V. Schesmer
Re: XSD Editor in Eclipse? [message #21607 is a reply to message #21315] Wed, 07 May 2003 07:23 Go to previous message
--------------C73E40C23BB0EDDFEFD9D8DB
Content-Type: text/plain; charset=us-ascii
Pae,
I'm just referring to doing this in the Explorer view:
[Image]
The Sample XML Schema Editor is an integrated editor that only works in
Eclipse. (It's built using parts, i.e., org.eclipse.xsd.edit, that can be used
outside of Eclipse.)
Pae Choi wrote:
> Ed,
> you.
> Pae
> > Dirk,
> and do
> and
> the XML
> next
> you get
> > > Hi all,
> and
> > > then...
> > > Thanks,
> > > Dirk V. Schesmer
Content-Type: multipart/related;
boundary="------------C4D8FB8D0ACBEA3D2D4C355A"
--------------C4D8FB8D0ACBEA3D2D4C355A
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Pae,
<p>I'm just referring to doing this in the Explorer view:
<blockquote><img SRC="cid:part1.3EB8ECB4.79A7BF99@ca.ibm.com" height=181 width=412></blockquote>
Eclipse.&nbsp; (It's built using parts, i.e., org.eclipse.xsd.edit, that
can be used outside of Eclipse.)
<p>Pae Choi wrote:
<blockquote TYPE=CITE>Ed,
<p>I have some questions regarding on this subject and hope you folks do
<br>not mind me continuing this thread.
<p>What does that mean when you said "just right click and do ..." in your
<br>previous post? Was that for the Eclipse/Editor?
<p>Is XSD Schema Editor pluggable to other apps other than Eclipse/Editor
<br>as well? Then, is there any doc and/or sample as a starting point?
Thank
<br>you.
<p>Regards,
<p>Pae
<p>"Ed Merks" &lt;merks@ca.ibm.com> wrote in message
<br><a href="news:3E95B805.918F9DFA@ca.ibm.com">news:3E95B805.918F9DFA@ca.ibm.com</a>...
<br>> Dirk,
<br>>
<br>> There is a Sample XML Schema Editor that XSD provides; just right
click
<br>and do
<br>> "Open with" to try it out.&nbsp; EMF also lets you generate a model
from a .xsd
<br>and
<br>> then generate an editor to edit model instances (i.e., XML instances
of
<br>the XML
<br>> Schema).&nbsp; There will be a tutorial for how to do this available
with the
<br>next
<br>> code drop.&nbsp; For now you can follow the existing tutorials at
<br>> www.eclipse.org/emf and choose the "Import from XML Schema" option
when
<br>you get
<br>> to that part of the wizard. Or wait till next week...
<br>>
<br>>
<br>> "Dirk V. Schesmer" wrote:
<br>>
<br>> > Hi all,
<br>> > when surfing and scanning the messages, I got the impression that
the
<br>> > EMF/XSD library contains an editor plugin for Eclipse ? Is this
correct
<br>and
<br>> > how can I get a good starting point to use it? I could replace
XMLSpy,
<br>> > then...
<br>> >
<br>> > Thanks,
<br>> > Dirk V. Schesmer
<br>></blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.3EB8ECB4.79A7BF99@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\merks\LOCALS~1\Temp\nsmail2C.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CAC1AZwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDoKqXMGZFZGYMzdAQBnHfg 9hVkh+zL/wB8
/wD1/pTJM74s/wB8/wAjQNNrYpD7ID5b7do+Vis5IU+h9P8A61TandS2kCPA iu7OFAIJzkH0
qoilIpkWN/KWIgGSPDJ/sg9x/hUuuAm2hCuEPnLhicbeDzmqS1sS9iiutXzq WWCNgASSEY9O
vf3FH9tX2wP5EewjIbY2OuPX1qBbhUSSSNlC7MCMgDJ3LngdiP6joKd5iT2j xoyqMMsauwXj
MeOpxk4J+ua0suxNyZdYv3jMiW6Mi9WCMQPxzTV1y8YMVihIQZPB4GQPX3FV FXMBE/lbUVgr
CQFh1wAAeRn271K0giM5QweWUIiACHI3rjI6k49eaLILsl/t+6/55w/kf8aP 7fuv+ecP5H/G
mobYLnZExODJl1UAFVzjIJ67vu8j8qajwFo1YQ7cxKflX7pX5+fqOvUUWXYN ST+37r/nnD+R
/wAaP7fuv+ecP5H/ABqArD9gYfISFBVtyg7sjIxjdxk9Tjj6UyFFBaMmJ3Dl Yj1y3+H1747b
qLLsF2Wv7fuv+ecP5H/GrVjqlzPdwxSxxKkoJBUHOBn39RVVbVvLi3QbDjhC gbLbTgluo+bH
Dcfh0mtopk1KzaWMLtjYMVACjlvTjuKT5R6m5RTd6/3h+dG9f7w/Osih1FN3 r/eH50b1/vD8
6AHUU3ev94fnRvX+8PzoAdRTd6/3h+dG9f7w/OgB1FN3r/eH50b1/vD86AHU U3ev94fnQXQd
WX060AOooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA Kr33/Ho/4fzF
WKr33/Ho/wCH8xQAy2/1yf7h/pVuqlt/rk/3D/SrdABRRRQAVDcqHVFKbiW4 +Yrjg9xUhD9m
X/vn/wCv9KpXFy6zsu5AITuOVJ4I69ffFJuxUYuWw3Nrv2OVK52sVnLbT6Gr N7aR3sQjlLAB
t3yn/PrWfBkW8gVG8oQHDOmCn+yDjkf4VrSFljZkXewBIXOMn0zVbPQkzP7A tf8AnpN+Y/wp
p0SyGczScEKfnXgnGB09x+dLF5wZlZp2twVLEJIrdGzjJLdQnT/GpAhSSRox OGeSJl+/gp8g
Offg5zzj2p8zFZDP7Atf+ek35j/Cj+wLX/npN+Y/woCzsiKPtG4hRPksPm3r nafTG/7vH6U6
ZZkLIvnOiuQkeXBf5V/jHI5LdePy4OZhZDf7Atf+ek35j/Cj+wLX/npN+Y/w q7O7srCJZBKr
4Q4+UnGcn/Z55+nHOKrnf58GPPccZRty4OTuYsPlP+6eOOOvJzMLIgOiWYkW MyzbmBYDI6DG
e3uKeuiW0TCRXlJQ7hkjt+FPs1Y3UTOJvNELCUuG2hsr0zx2PTir7/cb6Ucz CyIHZt7fMevr
Td7f3j+dD/fb60lQULvb+8fzqOO7SVI3SQlZCQp55Iz/AIGn1m/ZbhYoUjG0 lPmO7GxwhXP6
jp6e9AGnvb+8fzo3t/eP51nJayKuYg8ZDAgME44IJwvHG7PvjFWLaBonfP3Q Aif7oyR/6Fj8
M96ALO9v7x/Oje394/nSUUALvb+8fzo3t/eP50lFAC72/vH86N7f3j+dJRQA izh3dFkJZCAw
z0yM1HcMSYMkn98n86hjswuoS3bMcsAFUHtgdfyqW46w/wDXZP50CNKiiimA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVXvv+PR/w/mKsVXvv+PR/wAP 5igBlt/rk/3D
/SrdVLb/AFyf7h/pVugAooooAKqXMGZFZGYMzdAQBnHfg9hVkh+zL/3z/wDX +lMkzviz/fP8
jQNNrYpD7ID5b7do+Vis5IU+h9P/AK1aVZCKUimRY38pYiAZI8Mn+yD3H+Fa shZY2ZF3sASF
zjJ9M02rMQ2aeOBd0rbRzzjPQEn9AakrDlSd45EHmyoASuY3HJjkB+8Sf7vt zWpO7srCJZBK
r4Q4+UnGcn/Z55+nHOKQFiml1Eixk/MwLAewxn+Yqid/nwY89xxlG3Lg5O5i w+U/7p44468p
ZqxuomcTeaIWEpcNtDZXpnjsenFAGjRRRQAU1/uN9KdTX+430oArSHDt8rHn spNNyf7kn/fB
/wAKc/32+tJSGJk/3JP++D/hRk/3JP8Avg/4UtFACZP9yT/vg/4UZP8Ack/7 4P8AhS0UAJk/
3JP++D/hRk/3JP8Avg/4UtFACZP9yT/vg/4UZP8Ack/74P8AhS0UAJk/3JP+ +D/hRk/3JP8A
vg/4UtFACZP9yT/vg/4VFPyYeCP3ydRjvU1Q3HWH/rsn86ANKiiimIKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKr33/Ho/4fzFWKr33/AB6P+H8xQAy2 /wBcn+4f6Vbq
pbf65P8AcP8ASrdABRRRQAVDcqHVFKbiW4+Yrjg9xUhD9mX/AL5/+v8ASmSZ 3xZ/vn+RoAp5
td+xypXO1is5bafQ1fkdYo2kc4VAWJ9AKykUpFMixv5SxEAyR4ZP9kHuP8K0 L5S9hcKoLMYm
AAHJODTaswJ6KzWL7JBCJ/IO0bnEhZTzkgZDH+Eccc/WmwmctBvMshBwF2vH gbz8xPfgD5W5
9+eUBqUVm2RuI98kzSyFYyZEEbfe9Bk4Pf7ox+lWH3/ahjzfKyN+P73bHfHr jjp/tUAWqajr
IpZDkAlfxBwf1FZsfm7fn89o948yQeYrOMN0TqvO37vH4ZAt6eu21xhwN7kb wc4LnGc89PWg
CzTX+430p1Nf7jfSgCs/32+tJVS61KG3uZInWQsp5wBj+dRf2xb/ANyX8h/j T5WF0aFUI9uI
9uPtmV8z+91G7PtjPt0x2pP7Yt/7kv5D/Gj+2Lf+5L+Q/wAaOVhdDEupTbq0 c4lZowXJx+7O
V9BxwWPOensakheaZ0Q3HBDndHht2Nvcrg9T0FMTVbWNFRI5QqgADA6fnTv7 Yt/7kv5D/Gjl
fYLouW8hlt4pGwC6Bjj3FSVn/wBsW/8Acl/If40f2xb/ANyX8h/jRysLo0KK z/7Yt/7kv5D/
ABo/ti3/ALkv5D/GjlYXRoUVn/2xb/3JfyH+NH9sW/8Acl/If40crC6NCobj rD/12T+dVf7Y
t/7kv5D/ABq8vlzRRSFWIOHXnGPSk01uF7l6iq/nH3/Mf4Uecff8x/hQBYoq v5x9/wAx/hR5
x9/zH+FAFiiq/nH3/Mf4Uecff8x/hQBYoqv5x9/zH+FHnH3/ADH+FAFiiq/n H3/Mf4Uecff8
x/hQBYoqv5x9/wAx/hR5x9/zH+FAFiiq/nH3/Mf4Uecff8x/hQBYoqv5x9/z H+FHnH3/ADH+
FAFiiq/nH3/Mf4Uecff8x/hQBYoqv5x9/wAx/hR5x9/zH+FAFiq99/x6P+H8 xR5x9/zH+FI7
CRCrglT2z/8AWoAbbf65P9w/0q3VVSqEFQQQMdad5x9/zH+FICxRVfzj7/mP 8KWylaa2V3OW
Jb+ZpgT1DcqHVFKbiW4+Yrjg9xUhD9mX/vn/AOv9KZJnfFn++f5GgCnm137H Klc7WKzltp9D
WgzBFLMQqgZJJ4ArJRSkUyLG/lLEQDJHhk/2Qe4/wrRvN/2Ofy92/wAttu3r nHGKbVmBNTQ6
mRowfmUBiPY5x/I1nyvchRFEJfPEkpB2nbgh9vJ47rxTAuLh2jF15BCCQkSb iPn6Z+bqV6f4
0gNNHWRSyHIBK/iDg/qKdVK0IS18tkmCsZWzhsgbzj3yQeO9Ryed5J8xpg+4 ZAVjuXBwMp0P
qR39RgUAX3dY1DOcAkL+JOB+pp1ZciuxQSxziTzIiigsyhQVzkjg4O7k8/pW pQAU1/uN9KdT
X+430oA5bV/+QnP9R/IVTrU1KxuZr+WSOPKkjB3D0qt/Zt3/AM8f/Hh/jW6a sQ0ypV11Xzpo
NiiGNWKttGeB8p3d88e3PHam/wBm3f8Azx/8eH+NONjfmMRlWMYOQu8YH4Zo bXcVmONnA08q
KXRYXKsWbOQAxzwOPu+/WmvBbRxtL+8kTKgBWx13dyvP3fT+VSTW+pTy+Y4b IYsv7wfL9OeK
jexv5CS6sxYgnLg5x070rruMjWEJcz2xwxwyK2O4ORgepxj8atCCETrtKMrs kQwB1DYLDr2U
H/gf5wfYL7zPM2NvzndvGc+uc0Cwvl27UYbTkYccH16+wp3XcCQ+SolHltj7 MhbawGc7OnHH
61TuIxHLtXOCqsM9sgHH61Z+w3+wJtbYBgLvGOufX1pDp16xy0ZJxjlx/jQm u4WZToq3/Zt3
/wA8f/Hh/jR/Zt3/AM8f/Hh/jT5l3FZj547YaXbvnFwc8D+Ibjyf8f8AI2bb /jyt/wDrktYf
9m3f/PH/AMeH+NbsKlLWBGGGWMAisp2sVEfRRTJohMm1iQM54x/WsyxoaHYk QiQkqoZuMqW4
pJHa3inLHeYQT6Z4z71CiPG8a7GK5U9Bxg5PT/61TyobhLhSCnm5AzgkfKB2 qml0JVxsNwHX
cxi2lgoMcm8Z9CcDHb86BdxmUrzt2Bw+DjHPfoBx170pilkRkmkQq3BCoRkd x1NNa2Z9waTI
kTy3+XkjnGPQ8/8A6qkocbuIDkvknG3y23dz0xnsfypRcRkqASS3YKTjtz6f j6GoorMRurfu
1KtuxHHtB4I/rQLQiRWDgYYsSFwxyxbGc9OemKAJI7qNwnzcsAcgEqM9BnHv 39RSw3Ec2NhP
IyMqVyPUZ61DHZmNFjEgKAoW+XklQMYOeB8o/WpYrfy/J+bPlRmPp16c/pQA xbo7syIqRl2Q
Nv8A7ueTxwPlPenNdxKMkkAE53KVIGCc4x7H9aRbOIRyqVG6XcGcKA2GJOM/ j+lMls2nDGSU
byNuVTAxtYdM/wC0aAHteRrswHO5tpGxgw4JzjGT0/zinXNx5G37g3Z+aR9q j2zg8/4Gklty
8/nK4VwBtyuRxu68+jGpJBKceU6L67kLf1FAEU9z5cUmBmVELEAEqCBnBOP8 Kd9pi2k5YEHG
0oQ35Yz2P5H0qL7GVheGOQCN02ncuT93bnOR6DtTri0E0hclScLhXXcON3Ud /vfpQA83cION
x6Z4U8dRg8cHIIx1zSm4jCqxJ2t32nA9c+n41EtmFGAwH3OFTAG1i3A/H/8A XTJrDzEZd6Hd
u+/Hu25JOV54PP6CgCW5ufIdF/djeCcySbBxj2PrRLc+XtXH7wsisACVGSM8 49D39qdLFI0q
SRuqlVK/Mu7Oce49KY1tIzf61cM6u42dSMdOeB8o9aACG8SQMWBAUA5AJByA eDjrz0608XUJ
ZV3HcxIClSD27fiD9OaijszHF5YkGMKeV/iXGD16fKOP1qSK3KT+czhnIO7C 4HO3pz6KKAJ6
KKKACnab/wAeSfVv/QjTadpv/Hkn1b/0I0IRaqC62lFDKCN3dyuODzkVKQ/Z l/75/wDr/Sor
gMQgHJ3HGOP4T7/1pgVmW3UqJQAj5G4TMR+P51oVSlVxaz7g33D1P/2Rq4yh lKnOCMcHB/Og
ECsHUMpDKRkEHgikd1jUM5wCQv4k4H6msy3lm+yxhjMzyNCysAxG3Cbueg6N nP8AWkMVwLe2
C+aWdEaTzCz4cOnUE8dW44/SgDWoqK2z5W1w4dThtxzk+oPcf5wOgloAKKKK ACmv9xvpTqa/
3G+lAFaQKXbIJ5/vEfyNN2r/AHT/AN9t/jTn++31pjsRtVMF2OBmkMXav90/ 99t/jRtX+6f+
+2/xoDqxYI27HcUA5OACfcA4/OgA2r/dP/fbf40bV/un/vtv8aXPIHrRQAm1 f7p/77b/ABo2
r/dP/fbf40tFACbV/un/AL7b/Gjav90/99t/jS0UAJtX+6f++2/xo2r/AHT/ AN9t/jS0UAJt
X+6f++2/xqpqd5JaLD5aqdwOd2T0P1q5WXr3S2+jfzFVBXYnsQf2xcf3IvyP +NH9sXH9yL8j
/jVv+z7P+x/P/j8rdv3/AMXp6deKxK1Si+hDbNP+07z/AJ4L/wB8H/Gmf2xc f3IvyP8AjWrO
8qRRZZktzEMsqhgD33d8fT3rH1CKKHUSh3eXkFsYzjvjtUqz6Ddx/wDbFx/c i/I/40f2xcf3
IvyP+NRtAsrptESxnOXizjjHXeR6j060rWKpw0xySSNqgjaFDE5z1wfz796q 0RXY/wDti4/u
Rfkf8aP7YuP7kX5H/Go/sSfIDK26VtsfycHIUjPPH3h609rJZMOZEiBVAMlQ M7FJJyR69s0W
iF2L/bFx/ci/I/40f2xcf3IvyP8AjVa2iWbdGQ27hgwGcAdRj3yMe+B3qwYr Zo45RHsABkdd
xO5dxAGe3QDP+1ntRaPYLsX+2Lj+5F+R/wAaP7YuP7kX5H/GodQhjhmCxrtH zd89HYfyApI1
ja3IRY2l2kkOW3cZORjjGOeff2o5Y9guyf8Ati4/uRfkf8aP7YuP7kX5H/Gm LBDGbiN3YmNM
MRGDtIdRxzz39KFsARuaZVBI2FiB1APOSMcMOme/4lohdj/7YuP7kX5H/Gj+ 2Lj+5F+R/wAa
jFkjbQJW3NsH3ONzjIHXp1yf0NM+y/6KZt2GUBihx0JwO+e47Ci0Quyf+2Lj +5F+R/xo/ti4
/uRfkf8AGomWFLOJtsRkdCTuL7vvEZGOO1SLaxrFPHu3SRthiUwAQrng555H t0HFFo9guxf7
YuP7kX5H/Gj+2Lj+5F+R/wAajuLeBJ5yHdYo32cJkgknjryOOv6VHc2wtgoa QGQk5UDphiOv
4f57lohdlj+2Lj+5F+R/xo/ti4/uRfkf8az6KfKhXZof2xcf3IvyP+NH9sXH 9yL8j/jWfRRy
oLs04NVnknjRkjwzAHAPr9a2tN/48k+rf+hGuXtP+PuH/rov866jTf8AjyT6 t/6Eazmkti0y
1UF1tKKGUEbu7lccHnIqUh+zL/3z/wDX+lRXAYhAOTuOMcfwn3/rUDKzLbqV EoAR8jcJmI/H
86uzNGsMjS48sKS2RkYxzxVWVXFrPuDfcPU//ZGpr5S9hcKoLMYmAAHJODQC J6KzZPtO5/J8
37RmTOc7NuG2Yz8v9zpz696lsmU3UyxmbYEQ4lL5By2cbuewoAu0UUUAFFFF ABTX+430p1Nf
7jfSgCncB2c7AT14DbeexqFYgZ/3xL5yFwMAkdfyqy/32+tNVEVi4Qbj3pAO zxgABR0AGAKj
KsYtm3ou3ORjpT6KBjSu5y5jGMjCnB7N/iKcetFFABRRRQAUUUUAFFFFABWX r3S2+jfzFalN
miSVU3xxvgcbx05+lOLs7iauctRXS/ZIv+eFv+X/ANaj7JF/zwt/y/8ArVr7 RE8pnPqcEgTf
bFiqhc7iMgdiAefxqnd3X2i6M4XB44IyK3fskX/PC3/L/wCtR9ki/wCeFv8A l/8AWqVJIdmY
H2qXcDlQAMbQihT+GMHoPyHpQ11M5yWHQjhQOqhT+gArf+yRf88Lf8v/AK1H 2SL/AJ4W/wCX
/wBanzrsLlMP7bKIVQbdynO8qCRwAMccY29RTBdTDow6AAlQduAAMehwByPS t/7JF/zwt/y/
+tR9ki/54W/5f/Wo512DlZzgdhGUB+UkEj3GcfzNLLNJM26Rtx57Y6kn+ZNd F9ki/wCeFv8A
l/8AWo+yRf8APC3/AC/+tT9og5TAkupZVKyFWySc7Fzyc9cZ6k00TusflrtA xjIQbvzxmuh+
yRf88Lf8v/rUfZIv+eFv+X/1qXtF2DlOfe5lcEMV+YYYhQC3IPJ78gUouph0 YdAASoO3AAGP
Q4A5HpW/9ki/54W/5f8A1qPskX/PC3/L/wCtRzrsHKc+LmUEEPyCpHA6qMCj 7TKYjGSu0gAn
aMkDoM9ew/Kug+yRf88Lf8v/AK1H2SL/AJ4W/wCX/wBaj2i7BynP/aJPKEfy FQCBmNSQPrjP
enG7mKldy89SEGTwRycZPBP51vfZIv8Anhb/AJf/AFqPskX/ADwt/wAv/rUc 67BymB9ql3Fi
VJI53Ipz7nI5Pv1pkkryY3sWIGAT9Sf5k10X2SL/AJ4W/wCX/wBaj7JF/wA8 Lf8AL/61HtF2
DlOaorpfskX/ADwt/wAv/rUfZIv+eFv+X/1qftEHKc1RXS/ZIv8Anhb/AJf/ AFqPskX/ADwt
/wAv/rUe0Qcpz9p/x9w/9dF/nXUab/x5J9W/9CNQLbRKwYQwAjkFRyP0qfTf +PJPq3/oRqJS
5hpWLVQ3Kh1RSm4luPmK44PcVIQ/Zl/75/8Ar/SmSZ3xZ/vn+RqRlPNrv2OV K52sVnLbT6Gt
GshFKRTIsb+UsRAMkeGT/ZB7j/CtO48z7PL5P+t2HZ9ccdabVmBJTIoY4V2x RpGpOcKoAzWe
+/a/lNcCDK4DLIWY/NkZ+8B93np9eRRI1wJoSFkjYGNdnzuCCRuywO3uRyM8 Z9KQGkWAIBIB
Y4GT1NCsGGVIIyRwe461mbN8ULSi5Lo4af8A1nB2sPlx7n+Hj8KH+0Yl3efv +fyNu7G7e2M4
4xjZ97jH40AalFZrJcrGXhMvnPJKMMxIx8+3g8DkLz/jTm2fJj7X9n+bd/rd 27jH+1jGfagD
QphYPEWUhlK5BB4IqhElyFMspl88SRAjcduCE3cDju3NNiRo7S2iCyrtwJCd 5wwAGOvTrz93
igCxKMygckbjwCRng+lNRC0hKsUGdu0qzdgc5PTrSz535CluTkDHcEd/rUIe MZDlEIY8OVz0
HsfSgTJIpC2QylXHUEEUxJmcCTaiwEbt7Pg49cY/rTw6STsUYMNijI/Govs7 eWYPMHkFSm3b
8wGMdc/0pFDjdxAcl8k42+W27uemM9j+VL9oi2s2/hF3NweBz/gePaoZLecy xyh0Mm4ZOz5Q
Ards+retL9m+eEHkKWdm6ZJIbGPrg/8AAcd6ALVFFFABRRRQAUUUUAFK3Rfp /WkpW6L9P60A
JRRRQA3eNu7D7cZzsOKcCCAQcg0xG+VVLDBRQQW/2R23f0pFQBpoxu27sfeO eQO/WgSdySiq
CO8MI8rfJJJKyDcxbABbsSOw9RUguJdse4RqzkryfukHGTg9PbPXAzzwDLdF QWhkKOXcMPMc
LxyMMe+ar2xkjtEmYEu6oATKz53EDJB6de1AF+isx3mSeRN43mQfMAQOsQ6Z 96smeVWbJQqj
rGw2nLE45Bzx97pz0oAtUVDaSSS26SSbQXUNhe3H+f8APNTUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFO03/jyT6t/6EabTtN/48k+rf8AoRoQi1UNyodUUpuJbj5iuOD3 FSEP2Zf++f8A
6/0pkmd8Wf75/kaYFPNrv2OVK52sVnLbT6GtGshFKRTIsb+UsRAMkeGT/ZB7 j/CtWTHltu3Y
wc7c5/DHP5U2rMB1NZ1RkVjgudq+5wT/ACBqjsmkaJZTOCZPnwxUbNrY5Xjr jPv7YqJFmLW5
mExXasj8NkMUk3Y7jtwOnGOtIDVoqrA8iKxmWVpMqMYzwTgHjj6/j2xTH8zz JMNMseG8ttpb
DYOTjqR6A8df9mgC7TY3WWNZEOVcBgfUGs5N+1PNW4EGWyVaQsx+XBx94D73 HT68GrlipSwt
1YFWESggjkHAoAnpr/cb6U6mv9xvpQBWf77fWo1ljZtqsCaZf/dP+/8A41Vh haYnb24zz/Sk
BoUU2I5jX5SMAAgjHOKRCfLDZYjbklhgZ44HH19aBj6KYXI6jGDgk5AHT29x RuYKOASWIGM+
p9vagB9FAzgEgjPY0UAFFFFABRRRQAUrdF+n9aSlbov0/rQAlFFFADVNwihV lXAGB8n/ANeh
FYFi7BmY5JAx2/8ArUgZjGW/d5C7tu/nGM9MUsciyLuU5HT6UCBoo2QoyKUJ yVI4POf50eVH
tK7FwV2kY7en0pI5opc+VIj467WBxT6BjQiqzMFAZvvEDk/WmLbQJnZBGu4Y OEAyPSpFYMoZ
SCCMgjvS0ARrbwopVYo1BBBAUd+v8hSiGIMrCNAyjCnaMgegpZJY4l3SOqDO MscUnnR+SZQ4
MYBJZTkYHWgByqFUKoAAGAB2paarqxIVgSOoB6dv6H8qdQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAU7Tf+PJPq3/oRptO03/jyT6t/6EaEIkeceZCsZVg77Wwc4+Ut/Qfn T5IklUBwSAc8
Ej+VZNpPNcXilURiCC7YOAOmeuM44zjP4Vd1Df8Au9nmN1/dpuXeeMfOv3fx 4/mLasJO5IbO
AjBViD/tt/jUzOqMiscFztX3OCf5A1mulwFkZTPuxM4+ZvvBvk4+hPHQ+9PC sb2EuJjKszls
htgXDbf9npt9/wBakZo0UUUAFFFFABRRRQAU1/uN9KdTX+430oApXURlyoIH zZ5qKOGSMMu1
ZASDkMB6+o96sv8Afb60zem3duXGcZz36UhhGpVDuULlicZB7D0pcDAGOAAB +FLRQAm1MY28
Zzjcef19qCAc5HJOepoLAEAkAk4HvS0AHAGAMCiiigAooooAKKKKAClbov0/ rSUrdF+n9aAE
ooooAIlkKIQGxtXofYf7X9KjkVWNyrglCSGAzyNo9KPIT/a/77P+NORFQELn k5OTmgSVip5k
gVpA8jJGVI3rtLHkFcYGeMY96CsqywhmeRuCygsACTknd0IHoew/O4VDDDAE ZzzS0DMwRyJb
wIDKiquJPldvmwOmCDjr04qRI5mkHmGb5nCsdxXjywexwPm9PpV+igClIZGt 7R3MiuCC5RMs
DsPbB7n0pl3mSGQHz2UxYjwrAluc5AH068VoUUAZ4SYSSviTzSrCI84yGfGe 3QjGfwpQrvKi
xNOsBYZLFgfutnrzj7v9Oav0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFO 03/jyT6t/wCh
Gm07Tf8AjyT6t/6EaEIVWihaJLZYgjyYYIB/dJ7d+BVmsa0nmuLxSqIxBBds HAHTPXGccZxn
8Ku6hv8A3ezzG6/u03LvPGPnX7v48fzFyVtxJlyms6oyKxwXO1fc4J/kDWa6 XAWRlM+7Ezj5
m+8G+Tj6E8dD708KxvYS4mMqzOWyG2BcNt/2em33/WpGaNMklji2+YwUMSAT 06E/yBqhdG4l
kR0aWJWjBRRGxIbnIOCAP4fvcfrUV2spyQLg3CtKRgPtA2vtx/Dn7vTn8c0A aysGGVIIyRwe
460tVbJPLMykSBzIzHdnbgsSMduh7fjVqgAooooAKa/3G+lOpr/cb6UAVLjG 2XcxVcHLDqB6
1hjJyP4euB0+uK3n++31qH7ND5ezy1253Yx3qGrm1KpyJjodvkptYsu0YJ6k VnwMqWkLWao0
qx5kCDOflP3sd92Pfr71p0VRkZhmmIVg6TFGJTad+TsfjIAHpx1/SjzHfYXu F2JID5qMG2/K
w5O0D0/P3FadFAFKGaZrwqzpjcwMeeQBnBxjI7ck459xV2iigAooooAKKKKA Clbov0/rSUrd
F+n9aAEooooAKiunaO1mdDhlRiD74qWmuiyIyOMqwII9qAK0kzWp2uzTBlyM gZByBjgdPmHb
P1pomlnnhXyygG4sCzLnBXkcAnr0OBVgW8YVlwTu6lmJPHTk80qQRxsGUHcA RkkknOOpPXoP
yoAg+3fvNvl5BI2sM4ILAZyQP7wPGajubmQXO2PgqduCeGyY/wD4oirItIQc 7T0wBuOFHB4G
eOg6elAtIRn5SSc8liT27k/7I/KgBl08qrCF3BnfDCPBP3SeN3Hao7iWVLaV EyXWIuzOwVhn
OMYGMjB9KsvAkiKrbsIcghyCOMdc5pr2kTrtYORjB/eNkj0Jzz+NAECXTiSZ mGYo1LNk8jDO
OOOfuintdSJIImhBkJAAV+MENg5x/sn/AOv0qX7PFnOzrnIycHOScjv1PX1o W3jQhgCWByCz
EnoR1P1P50AS0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAU7Tf+PJPq3/oRptO 03/jyT6t/wCh
GhCHEJbNDHDGiLJIQQq4/hJzx9BViiiqYBRRRSAKKKKACiiigAooooAKa/3G +lFFAFZ/vt9a
SiikMKq2s8r+V5pQ+bH5g2qRt6cdTnr+lFFAElwzAxIrFfMfaWGMjgnjP0qa iigCNpCLhI+M
MjMfwI/xqSiigAooooAKKKKAIIbgyXVxCVAERXB9cjNMuII98bYbLyqD8x6E 0UUCLn9nWv8A
cb/vtv8AGj+zrX+43/fbf40UUwD+zrX+43/fbf40f2da/wBxv++2/wAaKKAD +zrX+43/AH23
+NH9nWv9xv8Avtv8aKKAD+zrX+43/fbf40f2da/3G/77b/GiigA/s61/uN/3 23+NH9nWv9xv
++2/xoooAP7Otf7jf99t/jR/Z1r/AHG/77b/ABoooAP7Otf7jf8Afbf40f2d a/3G/wC+2/xo
ooAP7Otf7jf99t/jR/Z1r/cb/vtv8aKKAD+zrX+43/fbf40f2da/3G/77b/G iigA/s61/uN/
323+NH9nWv8Acb/vtv8AGiigA/s61/uN/wB9t/jUN1Y28duzIrBhjne3r9aK KAGw2cDyKGVi
ChP329verH9nWv8Acb/vtv8AGiigA/s61/uN/wB9t/jU8USQxiOMYUdBnNFF AH//2Q==
--------------C4D8FB8D0ACBEA3D2D4C355A--
--------------C73E40C23BB0EDDFEFD9D8DB--
Re: XSD Editor in Eclipse? [message #567664 is a reply to message #17293] Thu, 10 April 2003 14:29 Go to previous message
Dirk,
> Hi all,
> then...
> Dirk V. Schesmer
Re: XSD Editor in Eclipse? [message #570729 is a reply to message #17384] Wed, 07 May 2003 04:55 Go to previous message
Ed,
you.
Pae
> Dirk,
and do
and
the XML
next
you get
> > Hi all,
and
> > then...
> > Thanks,
> > Dirk V. Schesmer
Re: XSD Editor in Eclipse? [message #570870 is a reply to message #21315] Wed, 07 May 2003 07:23 Go to previous message
Pae,
[Image]
Pae Choi wrote:
> Ed,
> you.
> Pae
> > Dirk,
> and do
> and
> the XML
> next
> you get
> > > Hi all,
> and
> > > then...
> > > Thanks,
> > > Dirk V. Schesmer
<html>
Pae,
Thank
<br>you.
<p>Regards,
<p>Pae
<br>> Dirk,
<br>>
click
<br>and do
from a .xsd
<br>and
of
<br>the XML
with the
<br>next
when
<br>you get
<br>>
<br>>
<br>>
<br>> > Hi all,
the
correct
<br>and
XMLSpy,
<br>> > then...
<br>> >
<br>> > Thanks,
<br>></blockquote>
</html>
Previous Topic:Old Xerces Version
Next Topic:XML Editor
Current Time: Wed Oct 29 15:57:45 EDT 2025
Powered by FUDForum. Page generated in 0.04829 seconds
