Multiple Files [message #17268] |
Fri, 25 May 2007 00:59  |
Originally posted by: evaandoli.dodo.com.au
I have a top level XML document that contains references to other XML
document of the same format.
Each document has a list of values which have various attibutes.
I want to create an aggregate of these values so I can interrigate then and
ensure some of their attributes are the same.
I used an iterate and load combination to get all the XML documents.
But I'm unsure how to create the attrigation so I can query from the top
level.
Any pointers,
Stu
Re: Multiple Files [message #17372 is a reply to message #17352] |
Sat, 26 May 2007 09:55   |
------=_NextPart_000_012F_01C79FF1.6755CF00
Content-Type: text/plain;
charset="iso-8859-1"
Sorry little bit unclear with the answer (and equally maybe I wasn't =
clear).
Im using JET2.
So is this importNode something I should use before I call Jet or is it =
a Jet tag.
Stu
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f392v5$ut3$2@build.eclipse.org...
Stu,
To move an Element from one Document to another, you need to use =
Document.importNode.
Stu wrote:=20
I guess my idea situation on this would be to temporarily "merge" all =
the=20
files so I can perform XPath queries over the whole data.
I hope that makes sense.
Can you read in the XML and then add the whole structure as an Element =
to=20
the parent ? (I tired with load and addElement but didn't seem to work)
Stu
"Stu" <evaandoli@dodo.com.au> wrote in message=20
news:f35qft$v25$1@build.eclipse.org...
I have a top level XML document that contains references to other XML=20
I want to create an aggregate of these values so I can interrigate then=20
and ensure some of their attributes are the same.
But I'm unsure how to create the attrigation so I can query from the top =
level.
Any pointers,
Stu
=20
=20
Content-Type: text/html;
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16441" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Sorry little bit unclear with the =
answer (and=20
equally maybe I wasn't clear).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Im using JET2.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>So is this importNode something I =
should use before=20
I call Jet or is it a Jet tag.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stu</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f392v5$ut3$2@build.eclipse.org">news:f392v5$ut3$2@build.ecli=
pse.org</A>...</DIV>Stu,<BR><BR>To=20
move an Element from one Document to another, you need to use=20
Document.importNode.<BR><BR><BR>Stu wrote:=20
<BLOCKQUOTE cite=3Dmidf38bn9$9in$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">I guess my idea situation on this would be =
to temporarily "merge" all the=20
to=20
Stu
"Stu" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:evaandoli@dodo.com.au"><evaandoli@dodo.com.au></A> =
wrote in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:f35qft$v25$1@build.eclipse.org">news:f35qft$v25$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
level.
Any pointers,
Stu
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_012F_01C79FF1.6755CF00--
Re: Multiple Files [message #17389 is a reply to message #17372] |
Sat, 26 May 2007 11:01   |
--------------030408020007050306000708
Stu,
I was only answering how to do this in DOM. I don't really understand
whether you are trying to do something within JET or outside of JET and
them feed it to JET, so I assumed the later. I don't think JET itself
will provide anything that will make a bunch of XML documents look like
one document for the purpose of XPath evaluation.
> clear).
> Im using JET2.
> it a Jet tag.
> Stu
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:f392v5$ut3$2@build.eclipse.org...
> Stu,
> Stu wrote:
>> I guess my idea situation on this would be to temporarily "merge" all the
>> Can you read in the XML and then add the whole structure as an Element to
>> Stu
>>> Hi,
>>> level.
>>> Any pointers,
>>> Stu
<html>
<head>
</head>
Stu,<br>
<br>
one document for the purpose of XPath evaluation.<br>
<br>
<br>
Stu wrote:
<blockquote cite="midf39e9k$iq3$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16441" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Sorry little bit unclear with the
answer (and equally maybe I wasn't clear).</font></div>
<div><font face="Arial" size="2">Im using JET2.</font></div>
<div> </div>
<div><font face="Arial" size="2">So is this importNode something I
should use before I call Jet or is it a Jet tag.</font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div> </div>
<div><font face="Arial" size="2">Stu</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a href="news:f392v5$ut3$2@build.eclipse.org">news:f392v5$ut3$2@build.eclipse.org</a>...</div>
Stu,<br>
<br>
Document.importNode.<br>
<br>
<br>
Stu wrote:
<blockquote cite="midf38bn9$9in$1@build.eclipse.org" type="cite">
<pre wrap="">I guess my idea situation on this would be to temporarily "merge" all the
Stu
"Stu" <a class="moz-txt-link-rfc2396E"
href="mailto:evaandoli@dodo.com.au"><evaandoli@dodo.com.au></a> wrote in message
<a class="moz-txt-link-freetext"
href="news:f35qft$v25$1@build.eclipse.org">news:f35qft$v25$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
level.
Any pointers,
Stu
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030408020007050306000708--
Re: Multiple Files [message #18167 is a reply to message #17268] |
Mon, 28 May 2007 09:02  |
Stu:
Have you tried c:copyElement ?
Paul
> level.
> Any pointers,
> Stu
FUDForum. Page generated in 0.08745 seconds
