Home » Language IDEs » Java Development Tools (JDT) » Problem exporting to JAR file & running on command line
Problem exporting to JAR file & running on command line [message #183252] Thu, 21 October 2004 17:15 Go to next message
Originally posted by: curt.schwaderer.mchsi.com
I've created a Java application using 3 projects within the Eclipse Java
perspective, for convenience, I'll call them project A, project B, &
project C. Project A also includes a JAR file (xmlrpc.jar in my
C:\Java\xmlrpc directory).
If I run this application within Eclipse, everything runs fine - all the
classes and JAR files are found and things run correctly.
Now, when I do "File->Export", select JAR file (we'll call it foo.jar),
make sure A, B, and C are all checked, and create the JAR file, things
seem fine. But when I go to the command prompt and attempt to run (java
-jar foo.jar), it complains that /org/apache/xmlrpc/WebServer.class (one
of the classes in xmlrpc.jar) isn't found.
The application runs correctly if I run it in the context of the Eclipse
debugger. So, why is the JAR creation utility leaving out xmlrpc.jar from
the foo.jar file even though it's part of project A?? Or is that correct
and I need to do something to reference it? I've set my CLASSPATH a bunch
of different ways with no correct result. Any help/advice MUCH appreciated!
Curt
Re: Problem exporting to JAR file & running on command line [message #184413 is a reply to message #183252] Fri, 05 November 2004 08:58 Go to previous messageGo to next message
JARs in JAR is not supported by Java.
Dani
>Thanks,
>Curt
Re: Problem exporting to JAR file & running on command line [message #184434 is a reply to message #183252] Fri, 05 November 2004 09:04 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Take a look at the Fat Jar plugin (http://fjep.sourceforge.net/). It should
do exactly what you want (creates one jar file which includes all classes
from projects and referenced jars).
HTH,
Csaba
"Curt" <curt.schwaderer@mchsi.com> wrote in message
news:cl98u7$kj6$1@eclipse.org...
appreciated!
> Curt
Previous Topic:How to do code navigation programmatically
Next Topic:How to do advanced syntax highlighting in a Language Plug-in?
Current Time: Sat Jul 26 14:45:58 EDT 2025
Powered by FUDForum. Page generated in 0.18628 seconds
