Home » Newcomers » Newcomers » Eclipse 3.1M4 Linux-Motif crashes
Eclipse 3.1M4 Linux-Motif crashes [message #17248] Wed, 26 January 2005 10:05 Go to next message
Originally posted by: pb.psychicblue.de
I tried the GTK-Version of Eclipse for Linux, but since it was quite slow,
I decided to switch to the motif version.
The Problem is the motif Version crashes after a few clicks with this
message:
JVM terminated. Exit code=255
/usr/bin/java
-cp /home/pblue/eclipse/startup.jar org.eclipse.core.launcher.Main
-os linux
-ws motif
-arch x86
-showsplash /home/pblue/eclipse/eclipse -showsplash 600
exitdata /home/pblue/eclipse/eclipse -exitdata 6bc0008
-vm /usr/bin/java
-vmargs
-cp /home/pblue/eclipse/startup.jar org.eclipse.core.launcher.MainJVM
/usr/bin/java
-os linux
-ws motif
-arch x86
-vm /usr/bin/java
-vmargs
I use JDK 1.4.2.
Is anyone familiar with this problem and can give me some advice?
Thanks!
Rainer
Re: Eclipse 3.1M4 Linux-Motif crashes [message #17331 is a reply to message #17248] Wed, 26 January 2005 21:59 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I got the same problem, and eventually reverted back to 3.0.1 (Motif).
I have logged a bug (after searching for a bug of this type and not
finding one), and you can follow it here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83790
Feel free to add yourself to the CC list of this bug if you want to
follow the status of it.
Denis
Rainer Arnst wrote:
> Hello,
> slow, I decided to switch to the motif version.
> message:
> /usr/bin/java
> -os linux
> -ws motif
> -arch x86
> -vm /usr/bin/java
> -vmargs
> /usr/bin/java
> -os linux
> -ws motif
> -arch x86
> -vm /usr/bin/java
> -vmargs
> I use JDK 1.4.2.
> Thanks!
> Rainer
Re: Eclipse 3.1M4 Linux-Motif crashes [message #28743 is a reply to message #17248] Wed, 23 February 2005 05:12 Go to previous messageGo to next message
Originally posted by: hicham.dev.menara.ma
Rainer Arnst wrote:
> Hello,
> message:
Hello
I would like know if the Motif eclipse Version is faster than Gtk version ?
which linux distribution are using ?
hicham.
Re: Eclipse 3.1M4 Linux-Motif crashes [message #29653 is a reply to message #17248] Fri, 25 February 2005 16:54 Go to previous message
I am having the same problem with the GTK version on SUSE 9.1.
java2-1.4.2-129.10
Rainer Arnst wrote:
> Exit code=255
Previous Topic:adding javadoc statements in eclipse 3.1
Next Topic:starting eclipse
Current Time: Mon Jul 07 21:28:55 EDT 2025
Powered by FUDForum. Page generated in 0.10887 seconds
