Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Misleading error when creating Editor Part
Misleading error when creating Editor Part [message #17182] Thu, 01 November 2007 13:49 Go to next message
Originally posted by: no.ddress.now
Exploring the port of an existing Editor to Dltk 0.91 (Eclispe 3.3.1.1/JDK 1.5)
to pickup additional funcitonality.
Now to the point of just trying to get the Editor to open, but runinng into the
following -- very confused -- error.
The exception occurs when the editor part control is being created by
EditorReference#createPartHelper at the line "part.createPartControl(content);"
The createPartControl method is actually failing in ScriptEditor#installSemanticHighlighting
on the line:
fSemanticManager.install(this, (ScriptSourceViewer) getSourceViewer(),
getTextTools().getColorManager(), getPreferenceStore());
Except, in debugging, all of the class types are correct. Any idea how to figure
out where the real problem is?
Gerald
java.lang.ClassCastException: org.eclipse.jface.text.presentation.PresentationReconciler
at org.eclipse.dltk.internal.ui.editor.SemanticHighlightingMana ger.install(SemanticHighlightingManager.java:288)
at org.eclipse.dltk.internal.ui.editor.ScriptEditor.installSema nticHighlighting(ScriptEditor.java:2925)
at org.eclipse.dltk.internal.ui.editor.ScriptEditor.createPartC ontrol(ScriptEditor.java:1845)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Gerald Rosenberg
Certiv
Re: Misleading error when creating Editor Part [message #17343 is a reply to message #17182] Mon, 12 November 2007 08:03 Go to previous message
Hi Gerald,
Please check what your
SourceViewerConfiguration.getPresentationReconciler() method returns
ScriptPresentationReconciler class.
Andrei.
> on the line:
> Gerald
Previous Topic:code refactoring question, renaming a lot of procs names shared over many files
Next Topic:Heap error
Current Time: Sat Jul 26 19:53:21 EDT 2025
Powered by FUDForum. Page generated in 0.04211 seconds
