Home » Language IDEs » C / C++ IDE (CDT) » Debugging core files using CDT / gdb
Debugging core files using CDT / gdb [message #182184] Fri, 12 January 2007 14:04
Originally posted by: cjashfor.linux.ibm.com
Is there a way to specify a core file when I start up the debugger?
I tried adding the "-c core" switch to the "GDB Debugger" dialog in the
debugger launch config, but the CDT didn't like that. It wants an
executable name in there only... no switches.
As a last resort ;-), I looked in Help and found nothing about debugging
core files there either. I also googled: "core file" eclipse cdt
and didn't see anything relevant.
If there's some trick to getting this to work, I'd like to know what it is.
Thanks for reading this,
- Corey
Corey Ashford
Software Engineer
IBM Linux Technology Center, Linux Toolchain
Beaverton, OR
503-578-3507
cjashfor@us.ibm.com
Previous Topic:class wizard always says class name is empty
Next Topic:CPU doesn't support the debugger
Current Time: Sun Aug 31 15:04:55 EDT 2025
Powered by FUDForum. Page generated in 0.08279 seconds
