Home » Language IDEs » C / C++ IDE (CDT) » Howto suspend?
Howto suspend? [message #182176] Fri, 12 January 2007 13:11 Go to next message
Originally posted by: ed_06.tantec.de
I'm using CDT 3.2 and GDB 6.3 and would like to know, how to suspend a
(multithreaded) program out of an endless loop? In debugging mode there
is a suspend button, but I never succeeded to make it work.
My software sometimes catches all CPU load and hangs, but I have no
idea, where and why. If I could stop it and go into stepping mode this
would be easy to resolve, but I'm unable to do this. Any hints, how to
debug such a problem?
Ed
Re: Howto suspend? [message #182234 is a reply to message #182176] Sat, 13 January 2007 06:12 Go to previous messageGo to next message
forgot to mention Windows-XP, likely suspend works using Linux?
Re: Howto suspend? [message #186676 is a reply to message #182234] Thu, 01 March 2007 09:50 Go to previous messageGo to next message
Apparently suspend only works when not using Cygwin.
Torkild Ulvøy Resheim
Senior Design Engineer
Atmel Norway AS
Re: Howto suspend? [message #186812 is a reply to message #186676] Thu, 01 March 2007 12:55 Go to previous messageGo to next message
I'm using MinGW.
Re: Howto suspend? [message #186841 is a reply to message #186812] Thu, 01 March 2007 16:34 Go to previous message
> I'm using MinGW.
Ah, and it's not working? Have you tried with more recent versions of GDB?
I've tested with CDT 3.2 and GDB 6.4 to no avail. Even started looking at
the CDT debugger code to see if there is something obvious.
Torkild
Previous Topic:PowerPC Switches Extension for the Eclipse CDT released on alphaWorks
Next Topic:Mingw/Mingw GDB with Eclipse CDT (Managed Make)
Current Time: Sat Jul 12 17:42:31 EDT 2025
Powered by FUDForum. Page generated in 0.04189 seconds
